Can I tap into the highbeam circuit for ditch lights?
doug maverick
Doug
2023 Ford Maverick Hybrid
I'm considering ditch lights to help with very dark rural roads, but I encounter on coming traffic pretty regularly. I'm hoping that I can tap into the high beam wiring or fuse so that aftermarket ditch lights will turn on/off with the high beam switch, rather than having to find a button in the dark on my dashboard.
Any ideas if I could add some LED ditch lights to the high beam circuit?
Maverick123
Waiting
Keep in mind that in many (most? all?) places it's illegal to have high beams + other lights active at the same time
doug maverick
doug maverick
Doug
This is South Carolina. We don't have laws like that here.
Tbone289
MO
The BCM fog lamp circuit automatically turns off with high beams. Using that to power your ditch lights would work as you describe. That requires an F-150 headlight switch and FORScan to activate.
EDIT: nevermind, I misunderstood what you're wanting. You would still have a separate lighted switch to push if you did it that way.
doug maverick
doug maverick
Doug
ZeroDay
2025 Maverick XLT Hybrid AWD, 1984 Volkswagen Jetta TD, 2007 Volvo V50 T5 AWD
You would need to cut into the headlights and pull the signal from wiring inside of it. There is one post here with vauge instructions.
Quest
If you have LED , not without cutting open a headlamp.
If you have bulbs no problem
Carlitos_92
All Mavericks have had LED low and high beams since 2022.
garyp
Washington
22 ford maverick
I kind of understand. I dislike that the headlights automatically go to low beams when you get below 20mph, usually I slow down to make a turn and need the extra light to see the street or street signs. I guess they expect everyone to be driving in the city, not out in the dark countryside. Kinda like new cars with no spare, not all areas have cell service
Cancunbadlands
Cancun
Cancun
Carlitos_92
The "auto high beam" is a setting that can be turned off so they work like you expect.
Random881
Connor
2022 Ford Maverick XLT
If you take your headlights off of automatic and just switch them to "ON" they will stay on no matter what. But it'll also disable the feature where they turn off if they sense another driver on the other side of the road, or any ambient light that would normally shut it off.
GreigC
Greig
Valparaiso, IN 46383
2024 Ford Maverick Lariat AWD w/4000# Tow Package, 18" Rim Option
[/QUOTE
If you use the high beam as a trigger to a relay, and powered independently those high those ditch lights it would work fine
