Built-in Wheel Bearing
JimmyV
Jimmy
TX
2024 Ford Maverick XL AWD
Anyone come across a steering knuckle where the bearing is built-in to the knuckle? All parts places show a press-in bearing not the one I have. Any useful information like part numbers, service options are appreciated.
tia
Ford Maverick Built-in Wheel Bearing IMG_20260622_140224
Ford Maverick Built-in Wheel Bearing IMG_20260622_140231
Ford Maverick Built-in Wheel Bearing IMG_20260622_140220
BK007
BK007
OH
Ford Maverick Built-in Wheel Bearing 1782167624526-da
Bearing Assembly Wheel Hub - Ford (NZ6Z-1215-C)
2022-2026 Ford Maverick - nz6z1215c
Ford Maverick Built-in Wheel Bearing genuine-ford
  • Manufacturer:Ford
  • Part Number:NZ6Z-1215-C
  • Replaces:nz6z1215b
  • SKU:NZ6Z-1215-C
  • Positions:Front,LEFT,RIGHT
  • Other Names:Wheel Bearing, Front Wheel Bearing, Bearing Assembly Wheel Hub
  • Description:
    Maverick.
BK007
BK007
OH
Press new one into spindle an hub. The rear Awd has a bolt on bearing but the front is a press on.
This is for a Ford Focus But the same idea.
JimmyV
Jimmy
TX
I wish I had a picture for comparison with the supposed replacement. The press-in bearing that's supposed to fit is way too large for the hole and structured differently.
BK007
BK007
OH
I would take the spindle to a shop and have them do it for you. Then you can put it back together? FWD an AWD have the same part number.
El Kabong
Carnation, WA
A question: how many miles on your Maverick? Did you do a lot of high-speed driving or haul heavy loads with it? I have memories of my '96 Contour GL, which ate wheel bearings every 50k.
The replacement bearing presses in from the other side of your pic. It seems too large because you are looking at the side that has a rim (shoulder) in the knuckle bore to keep the bearing shell from moving inboard. The rust-colored part in your pic is the knuckle, the shiny part is the inner part of the bearing, as it looks like in your pic that you have extracted half of the existing bearing from its shell on the inboard side.
You need to press out the hub from the bearing then press the bearing out from the knuckle both in the outboard direction. The video posted above by @BK007 shows what I mean.
If you look at the pics posted by @BK007 you can see part #5 is a snap ring - this part prevents the bearing "shell" from walking out of the knuckle, and it's on the hub (part #2) or "outboard" side.
If you try to do this without a hydraulic press like in the video you're going to have a very bad time. As advised best to take it to a shop and have them do it.
BK007
BK007
OH
If you do it yourself or to check a shop's work
Don't press the bearing in backward!
These bearings have an integrated magnetic ABS tone ring on only one side. If you press it in backward, your ABS and traction control will fail instantly, and you'll have to buy a new bearing to fix it.
The Fix: Before pressing, touch a small paperclip to both sides of the bearing. The side that attracts the paperclip is the magnetic side—make sure it faces the ABS sensor!
BK007
BK007
OH
Or you can get the entire knuckle used at LKQ I have bought a lot of used parts from them over the years. Save time an money!
Ford Maverick Built-in Wheel Bearing 1782229911765-g7
I see you have a bearing press kit.
If you use that wrong - you will ruin the new bearing.
Perhaps you do know about ONLY pressing on cup/outer part for install.
But it concerns me you didn't leave the cone/inner attached to press the bearing out the correct side.
That tells me you may want to bring it in somewhere.
Or at this point - learn on the getting it out.
Measure twice cut once for pressing it in.
Exranger
Northern California
If you do it use the old bearing to press it in, it’s perfect size. Don’t forget snap ring…
JimmyV
Jimmy
TX
Thanks everyone. I couldn't wrap my head around the separation and the lip it was pressed against on the inside. I had given up before getting the hub fully out. I ended up buying a new knuckle and new bearing/hub repair kit and just pressed everything together with the screw press kit. I almost messed up pressing in the hub, because you need to brace the inner part of the bearing, not the outer. 😬 Back on the road again and wiser than before.
What does that mean you have to brace the inner part of the bearing, not the outer?
Because you should be pressing against the outer part into the knuckle.
Found something quick - like this following what he said?
AF Blue
US
NA
At 26:20 in that video ... it may explain when to use/press inner vs. outer.
Note: I know you need to lube the tool (screw), but not sure you want/need to lube the outer
part of the bearing the way it was done in the video.
kevinmccune
kevin
BATH CO ,VA
2022 XL maverick
would that be a bad thing? two of the most useless features I have ever had on a vehicle,some love em'.I don't see the need,traction control has got me stuck,ABS has almost wrecked me a time or two.(IMHO)
