Anyone install hybrid engine cover?
Adospeed
Ado
Colorado
Hybrid in Shadow Black
Plan on adding a cover and some sound deadening on the hood just make it a bit quieter.
Yeah, because on a good day the engine sound on the hybrid is still awful.
RevBo
Bo
Frisco, Texas
2023 Ford Maverick XLT
Here it is... 10 minutes of work due to busting out a 10mm socket. I ordered too many screws and nuts... Only needed one screw, one nut and one plastic ball screw.
Makes it look much cleaner. I have to wonder why Ford didn't include this on all Hybrid's. Thanks for the pics!
Deleted member 5597
Guest
So, is your engine quieter now?
Chris_G
NOVA
C-6 Corvette
Would you be kind enough to share the needed parts list?
Thanks!
clavicus
Johnnybayday
Orange County, CA
www.coastalfamilydental.com
Ford
Thanks!
Part Number​
Part Name​
Price​
Quantity​
Total​
LX6Z-6A949-B​
Cover​
$74.47​
1​
$74.47​
-W714647-S450B​
Engine Cover Stud​
$2.20​
4​
$8.80​
-W520201-S437​
Lift-Gate Finish Panel Nut​
$1.57​
4​
$6.28​
AA5Z-6N958-A​
Engine Cover Stud​
$10.67​
1​
$10.67​
Don't forget just order 1 of each. that looks to save you a little like 10 bucks. This is from Tasca. You may find it cheaper but I didn't.
Gr8Mustang
Digger
Kansas City, MO
2022 Cyber Orange Maverick Hybrid Lariat Lux w/360
Any chance you have part numbers on that Hybrid cover stuff?
Just as i was posting you added that info.
THANKS.
Mav_27
With all the posters complaining about their glowing red hot cat under the hood, do you think it’s a good idea to add more plastic under there? Maybe Ford left it off for a reason
cyberdog
Ray
2023 Maverick Lariat Hybrid
The cynical side wonders if the cover melts, should the surge/hot-red catalytic issue occur. - My mind works like that, I admit it.
At least there's a TSB, with a proposed fix by late March, so the issue will be a non-issue soon.
For the record, I like the look with the cover, just not sure about spending better than $100 for it, although, my brother would get employee pricing on it. - When/If my Maverick gets produced, most likely as a 2023, being a late order.
Kevin DeLuca
Kevin
66 Thunderbird, 02 Dodge Dakota 74 Corvette
Ecurtis
Evan
Minnesota
2022 Maverick Hybrid Lariat
I don't think that's true. It has the anchors already installed.... They also stopped installing them on the newer escapes. Its just a way to save money. That being said it is not just a piece of plastic but a thick foam... The same 2.5L is installed in the escapes I don't think a cover is going to do much for heat. I do hope to lower some noise.
Cubican
Pedro
Ridgeline, viper, c8
Looks great thank for all the info.
I am not sure why you would want to put something on the engine that can restrict heat transfer into the air. Ford designed the engine without it and a cover can make it run warmer than they designed it
Yeah, gotta keep that plastic intake cool or you might experience 'DANGER TO MANIFOLD!'
Egz
Fredericksburg, VA
2022 Maverick Hybrid Lariat, 1967 Fairlady
Got my parts yesterday, and I think one of them is wrong. lol
Ford Maverick Anyone install hybrid engine cover? 20220507_081735
Fortunately I had a 6mm nut to use in the meantime.
