Another underbody cavity close out- DIY
MYNOMAV
Keith
Oshkosh WI
2024 Maverick XL hybrid
I decided to make the left side underneath similar to what Ford did on the right side. I made it with HDPE .100 without any drilling into the truck. I did make a small mod to the exhaust tip. Now that everything fits I could make it in two pieces instead of three. That will be another day. The heating, bending, and cooling were the time consumers
Ford Maverick Another underbody cavity close out- DIY IMG_20250406_164943_777
Ford Maverick Another underbody cavity close out- DIY IMG_20250406_164950_693
Ford Maverick Another underbody cavity close out- DIY IMG_20250406_165026_201
Ford Maverick Another underbody cavity close out- DIY IMG_20250406_161727_964
Ford Maverick Another underbody cavity close out- DIY IMG_20250406_155850_714
Ford Maverick Another underbody cavity close out- DIY IMG_20250406_133401_195
Redline
Upstate, NY
Great job. With a little tweaking, you could probably sell a kit, if you kept it under $100. I have the Mabett version sitting on my kitchen floor waiting for spring so I can finally install it. And I need to get some replacement hardware that doesn't rust. 😬
nice work, however, I'm fairly confident your exhaust tip will melt the plastic near it.
Oscarcat
Eric
Encinitas California
Very nice write up and photos. The material you used seems perfect for this application.
canuckford
Lou
toronto ontario canada
2025 2.0L ECO, 2015 Transit T250
You did a nice job, but What's the reason for covering up? I think I missed that thread. And where did you buy the HDPE panels?
it'll just melt away the portion that may be too close. R&D at it's finest.
yep just a minor cosmetic issue. people don't look under there, anyway.
RivrMav
Ken
Missouri
2023 Maverick Lariat (Hybrid)
Avoid corrosion in winter climates where road salt is used.
MYNOMAV
MYNOMAV
Keith
Oshkosh WI
Thanks all. The panel is HDPE .100"X 24" X 36" and got at Menards. I'll be watching the exhaust temp and its effect.
Tbone289
Nice clean job!
Supposedly HDPE can take 175 degree heat spikes without losing it's shape and won't fully melt until about 225 degrees. It might get a bit toasty, but probably only while at a standstill.
MTData
Prior Lake, MN
2024 Maverick XLT
Would you be willing to post your .STL files on Thingiverse?
MTData
Prior Lake, MN
2024 Maverick XLT
Sorry, I thought that you 3D Printed these
710-oil-614
Cal
2025 Hybrid AWD Lariat
That will do nothing to avoid corrosion due to road salt in the North. They lay so much if it it turns into dust and hangs in the air and will find its way into every crevasse imaginable. The underside of my 2025 Maverick looks a decade old already.
And I fluid filmed within 24 hours of bringing her home.
MYNOMAV
MYNOMAV
Keith
Oshkosh WI
What is Ford hiding up in there? They are protecting something from water, mud, slush. Must be there for a reason.
