Alignment or Tire Issue or?
Douger
Doug
el cajon
2015 Fusion Hybrid
My '23 hybrid with 15,000 miles started wandering left to right a few thousand miles ago, most noticeable on the freeway at higher speeds. It didn't pull one way or the other.
I had an alignment done & all was well for a day, then it pulled to the right.
The alignment shop first checked tire pressure, which was fine, then swapped the front tires and said it appears to be fixed. It now wanders left to right & pulls slightly left🤔
Any ideas? Bad tire, poor alignment job or needs balancing? I pointed out rear alignment specs to the shop and they said that the rear isn't adjustable, I'm ignorant here. 🙃
The 2023 XLT wheels & tires are STOCK BTW.
I'd appreciate any and all input!
JP4AZ
Phoenix
I personally ditched the crappy factory tires at 35 miles and never looked back. My truck has been perfect from day 1. Sorry to hear about your problems, I would have to guess that the tires are the problem. I strongly recommend Michelin
Ford Maverick Alignment or Tire Issue or? 20240521_131127
Ford Maverick Alignment or Tire Issue or? 20221208_183210_resized
Ford Maverick Alignment or Tire Issue or? 20230106_140108_resized
Douger
Douger
Doug
el cajon
2015 Fusion Hybrid
Thank you both for the help, I agree both times. It's a bummer to have to replace new tires with other new tires, but not the end of the world. I have my eyes on the Michelin tires, but will take it to the alignment shop one more time and post back.
Montana
How bad of a pull are we talking here? Can't say the description sounds "normal". Borderline unsafe if it's just going to sway back and forth. Get it on a lift and get it checked out. Tire shops around you, dealership if you must... Get the alignment done and a balance if nothing out of the ordinary is found after inspection.
Decayed
yes
a car
This is why, unless something is obviously wrong (as it was in your case) I never let them touch the alignment. Every time I have, they have made things worse. When I was younger and more ignorant one shop screwed things up so bad the steering wheel was cockeyed by about 30 degrees.
Oscarcat
Eric
Encinitas California
If it is a "bad" tire - belt or chords broken, it should be covered under the tire warranty. Be prepared for them to duck and dodge; you hit a rut, you hit a curb, you went off-roading over rocks, etc. etc.
23minimav
C
2023 Ford Maverick XLT Hybrid
Was your alignment done by a Ford Dealership? The reason why I am asking because I tried to do my alignment on April 2024 at Firestone but they inform me they do not have the alignment software for my 2023 Ford Maverick Hybrid yet, so I had my alignment done in a Ford Dealership with no issues. The Alignment shop if it is not a Ford Dealership may not have the software for 23 hybrid maverick.
Duh! 3/36k = dealership (if for no other reason than documentation on a warranty claim later,). It could be software issue or sensors miscounting tire rotations? Who can guess?
MetalsGeek
Rough
Torrance, CA 90503
Down to just the Mav
OMG! (WTF!) Even an ALIGNMENT involves proprietary software? Seriously, I wonder what this involves. I can see commanding an ABS purge for service brakes, but wheel alignment?
jorl
FLORIDA
22 Mav HYB XLT
my lifetime FIRESTONE alignment was $200 and they DO align the rear of truck too-I can send pics of before and after spec sheets --and that was right after lowering it on EIBACHs
HoiToid
Hard to beat MichelinDefenders~~~ 80,000/6year warranty~~~ good investment
Douger
Douger
Doug
el cajon
2015 Fusion Hybrid
Thank you all very much! I'll try to respond to all as I don't know how to respond idividually🙃
Montana- It's not horrible, just annoying, a slight, but definite pull when I let go of the steering wheel.
Oscarcat - Thank you, I'll call the dealer, good info!
23minimav-Chuck's in Carlsbad, they have good reviews & seem to know there stuff🤔
Jorl-The specs would be great if you don't mind. I showed them rear end specs & they said that the rear isn't adjustable🤔
HoiToid-Looks like Discount Tire is the best price for these, gonna go that route if I can straighten this out (no pun intended).
trumpet77
2023 Maverick XLT, 2009 Porsche Cayman
If I understand the original post
A: pulled right
B: rotated tires
C: then it pulled left
If so, then I’ll guess it’s the tires, assuming the rotation swapped left and right.
An Easy/free way to confirm: rotate them right back and see if the pull goes back to the right!
cheaper than going after the alignment again.
James K
NY
2022 Maverick,1960 Bugeye, 1973 GT6, 2016 R1200GS, 2024 KLX300
I've also seen a bad CV joint cause pulling but rotating tires only switch the direction it pulls really indicates a strong possibility of tire problem.
