TPMS tire sensor issue
Kapusssh
abraham
cypress
maverick
Anyone else have a problem with the tpms sensor staying on. The maverick only has 250miles drive. My wheels and tires came from an fx4. Same specs. Confirmed it does have tpms. Light is on, took it to dealer, they said sensor isnt reading. Anyone else has issues with this?
Cubican
Pedro
Ridgeline, viper, c8
is it all of them, if it is you have no tpms in them
Kapusssh
Kapusssh
abraham
cypress
maverick
Yes it does we were able to reprogram / relearn it last week thru the on position while pressing on the brakes. It just recently decided to stay on
ffoc01
2022 Mav Hyb FE, 2014 Flex
When you put the truck in training mode, did you manually retrain each sensor with the TPMS training tool? If not, the truck likely never stored the sensors for the new wheels you put on.
Kapusssh
Kapusssh
abraham
cypress
maverick
Oh i see, no all we did was the on, off position with brakes and release air on each tires. I gotta get that tpms tool. Thank you for the info.
ValenciaOrange
Howard
Southern California
Yes you need the tool. They programmed my truck inside today, then they used the tool on each wheel..
Mkuket
Massachusetts
BTW on all ford's if you turn the key on and press the hazards on and off 3 times or also enters relearn mode. So much easier than the key on off brake pedal thing
PapaRico
Larry
DallasTX
Going to show my ignorance here, but how do you turn the key "on" with push button start? Actually start the engine and then do the hazards?
Push the button without holding the brake.
