Adding Paddle Shifters
2016BoostedGreyGoose
Lawrence
16 F150 CC XLT, 21 F150 RCSB, 22 Maverick Lariat
Ive made a lil headway. Waiting on my Bronco Sport rotary shifter with M (Manual Mode) before I can go any further but I have identified missing wiring that I will be adding back in and rechecking my pinout from the PCM to the GSM. Already toggled on the SST setting in the IPC that allows for paddle shifter upshift and paddle shifter downshift operation as well as programmed my Escape digital cluster to show PRNDM instead of the previous PRNDL. Will be looking at programming strategy to ensure there is no difference there. There may still be hope yet!
Ford Maverick Adding Paddle Shifters Screenshot_20220624-001603_Gallery
inthecabin
Andy
2021 Ranger Lariat FX4
It’s fun modding vehicles but why paddle shifters?
I don’t get it…
Lawrence
I don’t get it…
Ever tow anything? Holding gears manually prevents the trans from searching all over the place and almost always being in the wrong gear. Ask anyone that tows a lot if paddle shifters are beneficial or not. Besides...Race Truck!! :)
inthecabin
Andy
No I’ve never towed anything in my 65 years on this planet, race truck?? My last truck was an F150 2005 FX4 with a a 4 inch lift and 35 inch tires that has probably seen more flight time than most entry level pilots.. I have slowed down a bit on flight time with my 2021 Ranger FX4 but really paddle shifters and Maverick as a race truck??? Really… I’ve driven a few hyper cars in my days, the latest is a Ferrari 812 GTS but never could never keep up with the paddle shifters vs rpm.
So you think a quick shift is going to gain what?
BTW I’ve hauled and towed more than you can imagine!!
I like the spirit but it seems wasted on a Maverick…
austinzone
Tampa
Honda Element
the maverick is a car chassis.
it weighs about 150lbs more than a 400z.
paddle shifters would allow for - more control on full throttle accel. it would allow for more control during cornering. more sporty overall.
volksnuts
Katy,TX
Maverick Lariat HPR
Well I know I’m excited, and I never tow anything
Not having control of what gear I’m in (and not knowing what gear I’m in) seems really weird to me
Also #racetruck lol
Lawrence
Seriously? It was injected humor. It's not a debate or life comparison. Lol it's ok to have a bit of fun.
Maverick2022XL
name
hinterlands
Frankly it probably is since the Maverick 2.0L ecoboost uses a CVT transmission and unless the CVT in the Maverick is designed to work like a gear based transmission adding paddle shifters is not going to bring anything to the table but most likely a blown out transmission earlier in it's life cycle and a multi thousand dollar replacement bill that will not be covered under the warranty. With that said your truck, your decision and all the advantages and problems that go along with modifications of it.
CVTs in the main will seek the best gear ratio because they are usually pulley based. You force it out of the best ratio as the system is designed you'll almost certainly overheat an already prone to overheating transmission if you do it long enough. You also most likely have to change the tranny fluid much more often when do this.
edit. my bad the Ecoboost has an 8 speed transmission not an CVT. The hybrid has a CVT.
Lawrence
I dunno what the hybrid version uses but the 2.0 ecoboost uses an 8spd auto, not a CVT.
Maverick2022XL
name
hinterlands
I just double checked and you are correct. I was under the the impression both engines came with a CVT transmission. Only the hybrid has the CVT. My original statement still stands but amended only to hybrid engine builds.
You're still incorrect that the hybrid CVT is pulley based. The powersplit eCVT design is planetary gear based; no belt or pulleys.
Jmav2152
Jamie
Cleveland, OH
Do you know if paddles will give you full control or is the system still going to override and take over when pushing it? That's always been my biggest gripe with paddles or any semi auto system. You can never really push it like a manual.
Lawrence
It is full control meaning the trans wont upshift until you do in manual mode.. in normal mode you will be able to lock out gears but the trans will otherwise upshift before you redline. BUT no one is going to like what you have to do to enable them. I'll share when I'm finished. It's intrusive.
MankDeems
Zac
Fargo ND
99 ranger 4X4 XLT, 04 Mazda6, 17 ninja300
Bumping this thread, any headway? mine has been built and is waiting to ship, I've been driving a 99 ranger XLT with a 5 speed for 3 years now and will do anything to prevent going forward.
Lawrence
Been really busy so I haven't had much time to work this out but I think I can work in some time next weekend. Most, if not all, will be extremely surprised by what needs to be done. I cannot say this part enough. According to my initial research, which I trust... this is a more "involved" upgrade. No idea why Ford went to such great lengths to ensure this was as difficult as gathering pee from a T-Rex. 😞
