Adding a 110V outlet to the truck bed
Badoswf
Joseph
Federal Way, WA
Does anyone know how to install the outlet? I have a Maverick XLT with the 2.0L AWD options and tow. Do I need to install an inverter or does the DIY stuff already have it set up from the factory? I've been trying to figure it out but I can't find anything on it.
FakeCowboy
Mid Atlantic
2016 Subaru WRX
it really depends on what you're planning on running off of the 110 outlet, you may be able to run it off of one of the 12v leads provided if you're planning on running something small like an air compressor. What are you planning on using it for? Also, I don't think factory inverter wiring exists to just run an inverter off of.
Maverickman74
Shane
Maui HI
You need an inverter. Buy it based on your needs a small 400 watt unit could go in the bed cubby and run off the pre wired 12v. If you need bigger you can mount it behind the rear seat and find a larger guage 12v wired source or run your own from the fuse box. Then run 110v to the bed from there. There are nice OEM inverters you can but from various car manufacturer parts department and retrofit for a factory look. There is a good thread already on that one. Or you can find everything you need cheap on amazon, just beware of inverter quality and read the reviews.
I dont want to drain my system and will be getting a bed topper and making my own battery and inverter in a box setup. Fully run off a solar panel to keep my fridge freezer ice cold.
wyouger
Williard
2011 Ranger
A 400 watt inverter is not recommended for the 12v in the rear. The 12 v connections in the rear of the bed are rated at 20 amps and a 400 watt inverter is rated at over 30.
Maverickman74
Shane
Maui HI
Weak. If i cant have 1000watts of rear facing led light bars whats the point?
Yeah I think I am gonna do a stand alone system.
wax87
Stuart
Dallas South
2004 Avalon
1000 Watts would be 83 Amps, that is a lot of heat, you had better have some heavy wiring for that.
