The Speaker Guy
2022 A51 Lariat Lux CP360 SIBL Hybrid
I do not recall seeing this this mentioned here, but it makes tons of sense as to why trucks seemed to be growing over the years:
"It comes down to how the government calculates fuel economy targets for light trucks. It’s a convoluted and somewhat contradictory voodoo formula that applies different efficiency standards to vehicles based upon their “footprint.” That is basically, the area a vehicle occupies – its length multiplied by its track width. The bigger shadow a truck casts, the easier the fuel economy standards it must meet. It’s a method of regulation that’s practically killed the regular cab pickup truck and made introducing smaller trucks, until the Maverick, a virtual impossibility. "​
From this article:
https://www.roadandtrack.com/news/a36697224/ford-maverick-had-to-be-a-hybrid/
The Ford Maverick Had to Be a Hybrid
How Ford is restoring hopes of a mini truck renaissance with a little electric help.
Ford, using a mix of imposed media embargoes, carefully metered press access and psychological manipulation, orchestrated an orgiastic blowout of coverage for the debut of its new Maverick compact truck. But missing from the Vesuvian spew of videos, blog posts and pandering news items was some important perspective. That includes acknowledgement that the Maverick will be the first small truck to be sold in the United States as a gas-electric hybrid. And the regulatory reason that the Maverick had to be available as a hybrid.
Think of it this way. Say you’re Toyota and you have the Tacoma to sell. Back in 2014, the regular cab Taco ran 190.4-inches long while the extended Access Cab model was 208.1-inches. The longest version that year was the Double Cab longbed at 221.3-inches. But while they differed in length, they were all basically the same truck. They were available with the same four- and six-cylinder engines; used the same transmission and powertrain components and shared virtually all their chassis pieces. Most importantly, all the 4x2 models had a 61.0-inch wide track while the 4x4s and PreRunner (4x2s that look like 4x4s) had 63.0-inch front and 63.4-inch rear tracks. Now let’s do some math.
Multiply the regular cab 2014 Tacoma 4x2’s 190.4-inch wheelbase by its 61.0-inch track and what results is a footprint of 11,614.4 square inches (80.66 square feet). Meanwhile a similar Access Cab model went out at 12,694.1 square inches (88.15 square feet) and the Double Cab crushed that at 13,300.13 square inches (92.36 square feet). That’s more than nine percent larger for the Access Cab and almost 15 percent larger for the Double Cab. Those numbers grow even more stark for wider 4x4 models.
Now it gets weird. Here’s the formula for determining the target fuel economy (T) of light trucks to meet Corporate Average Fuel Economy (CAFÉ) goals. These standards went into effect for 2011.
T = [1/a + (1/b – 1/a) e(x-c)/d/(1 + e(x-c)/d)]-1
where:
T – fuel economy target, mpg
a – maximum fuel economy target, mpg
b – minimum fuel economy target, mpg
c – footprint value at which the fuel economy target is midway between a and b, in square feet
d – parameter defining the rate at which the value of targets decline from the largest to smallest values, in square feet
e = 2.718
x – footprint of the vehicle model, in square feet
Footprint, that “x” value, matters a lot in this equation. And it matters even more in the context of managing a portfolio of diverse products across a manufacturer’s range. What it meant for Toyota back in 2014 was that there’d be no regular cab Tacoma for 2015. And there hasn’t been a regular cab Tacoma since. The Tundra regular cab was offed after the 2014 model year as well.
For manufacturers, killing the regular cab trucks was no great loss of business. Consumers have a strong preference for extended and crew cab trucks and the companies were unlikely to lose marginal sales. Larger medium- and heavy-duty trucks for commercial customers are still available with regular cabs.
But for the same reason that regular cabs had to die, so did the possibility of truly small trucks. Over the years, I’ve asked virtually all the truck builders about opportunities for a small truck in America. They all recognized there was a market, but that with the current footprint regulations there was no way to profitably get one to market. But with the hybrid version as the base configuration, Ford seems to have overcome that hurdle.
Hybrid systems have become more robust in operation and much cheaper to build. Ford and Toyota have been out front on hybrids for a while, so it's a good bet that Toyota could be next to offer a mini truck of its own. Toyota’s strength in the truck market has long been the Tacoma, so there’s no reason not to counterattack against the Maverick. After that, the other truck builders will follow in the hope of attracting entry-level buyers who become lifelong customers. And hybridization is the secret sauce that makes it possible.
Overhype and ridiculous hyperbole aside, the Maverick will herald the return of mini-truckin’. Dude. And dudettes.
technolithic
NA
“For manufacturers, killing the regular cab trucks was no great loss of business. Consumers have a strong preference for extended and crew cab trucks and the companies were unlikely to lose marginal sales. Larger medium- and heavy-duty trucks for commercial customers are still available with regular cabs.“
More proof that Ford is never coming out with anything less than a super crew or whatever the hell the 4 door is being called now.
dceggert
Dan
Metro Detroit
2017 Fusion, 2019 Ranger, 2024 Maverick ordered
You are missing the point. Customers BUY the extended and crew cabs and very few standard cabs. It costs money to keep that kind of complexity and even more for a unibody construction. The F150 is available in standard cab and they sell about .5% to retail customers. It is carried for the fleet customers. So that is available for you if you insist.
BDennis
Bruce
So Cal
If all by this is true, how did Hyundai built a non hybrid Santa Cruz?
The Speaker Guy
I thought of that too, but it may have to do with corporate average fuel economy. CAFE
BDennis
Bruce
So Cal
Big Ragu
Aric
Ohio
Bronco
The "footprint" issue has killed the regular cab. It would be cool to see a regular cab with a 12' bed lol. That would fix the footprint issue
adawalli
Adam
2017 Ford Explorer Platinum, 2010 Toyota Prius 3
This question only makes sense if Santa Cruz ends up being a (wild) success. Anybody is welcome build anything - doesn't mean it will sell. Time will tell for both vehicles.
Fish Chris
Sacramento California
Prius LE, Ford F150
All I can say is, "it had to be a hybrid if they had any chance of selling one to me, that's for sure"
I'll never own another all gas vehicle. I've been too spoiled with my Prius.... 53.6 mpg's for it's entire 53K mile's 😉👍
grumpyunk
tom
georgia
Hyundai does not builds an F-150 competitor or pickup truck and has a better CAFE makeup. They don't need the mpg to avoid paying fines?
Raschaef
Richard
Monkton MD
Nissan Rogue
From years ago I knew a finance guy at Ford corporate they intentionally lost money on low end car with high fuel mileage. Why? It was less than paying the fines for missing the ave fuel economy the Federal government mandates.
Art Vandelay
New York
2023 Hybrid Lariat Alto Blue
No, Dcegger is 100% correct that consumer demand has been the primary reason for regular cab trucks edging toward extinction. Ford, as well as all other auto manufacturers, have a pretty good idea of what sells and what consumer tastes are at every moment. If they're making almost solely crew cabs in their full size trucks it's because that's what consumers are demanding. Car internet forums aren't the best place to gauge consumer tastes because it's a small minority of enthusiasts.
I'm a manual transmission guy but even I know they're slowing becoming extinct. Many years ago I had a 2002 Maxima with a manual which was a really nice car and a super fun car to drive. Somewhere around roughly 2010 Nissan stopped offering a manual in the Maxima and the outrage on the Maxima forum was brutal. But the manual not being available anymore didn't even make a dent in their sales. Sometimes it's easy to get caught up thinking everyone wants the same features we want. I'm sure there are sedan lovers convincing themselves that SUV's aren't taking over which is obviously delusional. Heck, even Ford has, for better or worse, abandoned cars except for the Mustang.
The small minority of people yelling into the internet that they want a regular cab trucks are the same as the manual transmission holdouts who don't want manuals to die.
K5Blazer
Colorado
2023 Maverick XLT
Which is why American vehicles have gotten bigger, and bigger, and bigger….
