400 Watt Inverter- Is mine broke?
Brijar92
Independence, MO
2020 Honda CR-V
So I've never done anything with my 400W inverter until I was on the road the other day and needed to use it. Apparently I don't know how to make it work... or maybe it is broken/not working. How do I make it work?
scottp01
Poconos, PA
2014 Ford Fiesta (on death's door)
My inverter was never plugged in at the factory. Might want to have your dealer take a look at it.
Brijar92
Brijar92
Independence, MO
2020 Honda CR-V
I can't figure out where the indicator light is, I never see a light or a flashing light. Can you explain where the light is... I'm guessing it may be tiny. I'm wondering if the next poster may have explained why I'm having trouble, the inverter itself may not have been plugged in at the factory.
Brijar92
Brijar92
Independence, MO
2020 Honda CR-V
So if I walk to the back of my truck bed and I'm looking at the inverter plug-in and the truck is running, should I notice there being an indicator light that is lit? Or am I supposed to do something to make the indicator light up? Is it supposed to light up if I plug something in?
Brijar92
Brijar92
Independence, MO
2020 Honda CR-V
Thanks to the guys who responded. I found a video on Youtube showing me where the indicator light is. The guy showed all you had to do was start the truck and the light should be lit, indicating the inverter would work. I tried that with my truck, the light does not light up. Apparently as Scottp01 suggested, my unit was not plugged in at the factory. Unless someone knows how to do that, it is off to the dealer I go.
Johnkn
MD
Edited....
I’ll just delete my troubleshooting suggestions as it appears the OP would rather just flounder..........
tom_tucker
mid atlantic (VA)
2023 Maverick XLT (FWD)
Both AC outlets should have the orange light as you probably know. Only if the car is full on and "ready to drive" though. When I plugged in the outlet tester with the car on it lights up with "open ground", Probably cuz its a weak car ground vs. a real earth ground. I don't know shit about electricity though.
Nw_adventure
Salt Lake city
Lets party - )
Ford Maverick 400 Watt Inverter- Is mine broke? Crock
Joeneonturbo
Joey
Turlock, ca
Ford Ranger, Dodge SRT-4
Yes mine was not connected inside the rear wheel well behind the led box/inverter panel.
Brijar92
Brijar92
Independence, MO
2020 Honda CR-V
Thanks, when I use an outlet tester I get nothing in the truck bed or inside the truck. Also, I plugged in a small radio and got nothing. No little light comes on. I think they forgot to plug the unit into the actual inverter at the factory. Really appreciate your help. PS Yes the truck is turned on, ready to drive, lights off, hvac off.
Hardening2753
Ford Maverick Hybrid
What did the dealer say after you did your initial troubleshooting
bob o lish
2023 Maverick / 2014 JK wrangler 2 door
Read the dam instructions or google it.
