Is that the modular floor and tailgate cover? That was the setup I was thinking about doing, just the floor and tailgate, no sides.
I agree. I dig that height, now.Added a 2x4 to slide in right on top of the 2x6 and painted both black. I am happy now.
Not sure what you mean by the 55 cut. The first pic said it was 55 1/4. Yet it's to short.
I'm going to assume if you're wanting to place your lumber like this, you'll need the 55" cut. The above pic is using the same 2x6 I had in the original images. It's too short to be secure in this configuration.
The OP has 54 1/4”, not 55”. The 54 1/4 is for the slot behind the wheel well, the spot on top of the wheel well is 55”Not sure what you mean by the 55 cut. The first pic said it was 55 1/4. Yet it's to short.
2x6 at 54 1/4. It fits, I just think I want a taller one. Maybe 2x10? Might just stack a 2x4 over it. Don't know yet. Anyways, just sharing in case anyone wanted to see the 2x6 specifically. Going to paint whatever I use a matte black or maybe some type of bed liner spray if I can find some.
I made the 2x6 and painted them satin black. They came out nice. They make nice cargo compartments. If I did it again though (and I may) I'd make them 2x8's. The 2x6's are lower than the height of the wheel wells. If I put in 4x8' plywood, the weight would be mostly on the wheel wells. Only the sag would touch the boards in the middle.2x6 at 54 1/4. It fits, I just think I want a taller one. Maybe 2x10? Might just stack a 2x4 over it. Don't know yet. Anyways, just sharing in case anyone wanted to see the 2x6 specifically. Going to paint whatever I use a matte black or maybe some type of bed liner spray if I can find some.
I also went with stacking a 2x4 over the 2x6 but I find that most of the time the 2x6 is sufficient alone and leaves enough room to move a milk crate between the divider and the tonneau without opening the tonneau.Added a 2x4 to slide in right on top of the 2x6 and painted both black. I am happy now.
Unless you have small grocery bags, thi was lighter and easier to make.When I make my "grocery divider," I will build a 2x2" frame the size I want the finished divider to be, cut a 1/4-inch groove all the way around the "inside" of the frame, and cut a piece of 1/4" plywood to fit that groove. Secure the plywood to the frame with glue and a handful of screws, use a 2" hole saw to cut a whole bunch of lightening holes in the plywood, and you've got a very lightweight, rigid, and amazingly strong divider...
Going on past history making stuff this way, it will weigh a LOT less than a single 2x6, and can be as tall as will work with my tonneau cover. I want my wife to be able to put in in place or remove it without having to climb into the truck bed to assume a weight-lifting stance...
By the way, here's a picture from an earlier thread that shows the cut lengths for each of the locations in the bed. Sorry I can't give credit to whoever did the work on this - I saved it in my "Maverick" folder for future reference - like now!
