21650 miles CHECK ENGINE light on
Drew11115
Robert
Massachusetts
Ford Maverick 2022
2.0 eco boost. I run nothing but Shell Nitro since it's first fill up. There truck is in is's 5th oil change. I'm livid about this!
93nighthawk
Eric
South Dakota
what does your ford pass app say that is wrong?
Last Truck Ever
2023 Hybrid Maverick XLT
If you don't own a code reader, drive down to the local AutoZone or something similar, they will happily read it for free, print you out a report telling you exactly what the problem is.
ValenciaOrange
Howard
Southern California
Don’t worry it’s the weekend there is nothing you can do. Call the dealer on Monday. Maybe they can get you in, in 2 to 3 weeks. Now you need to worry. Hopefully it is an easy fix.
billbillw
Metro Atlanta
'23 Maverick Lariat FX4
Nothing to be livid about. It happens. No more, no less of a chance with frequent oil changes and using the best fuel top fuel. Something is off in the engine control system. Could be a sensor, a bad connection, or a number of other things. Enjoy the warranty repair.
fossil
ernie
ohio
only an emissions code, drive it until they can get it in for a look.
100% Agree. Maybe forgot blood pressure or anxiety meds? But the avatar and temper seem to match....
Motorjunkie
Hermitage, Pa.
73 vette, 71Fiat 850, 91 Mercedes 500SL, 2001 F150
Livid? It took 3 tries for my dealer to fix this on mine. It all had to do with the vapor canister, purge valve, and associated parts. Neither the fuel nor clean oil has anything to do with this. Relax and take it to the dealer.
