2025 XLT remote start with Cheap replacement key fob
Cancunbadlands
Cancun
Cancun
Cancunbadlands
Cancun
Cancun
2024 Lariat Tremor, I think it won't work neither
Cancunbadlands
Cancun
Cancun
Larry the lariat
Roli
Miami
Mazda B3000
I don't see this: "Remote start was already active in my 2025 cluster options"
Do you?
No I don't see that. I bought the starter X adapter for $100 when I originally bought the truck and it's worked flawlessly. I was hoping to at least have the nicer key. Lol. But hey, worth $25. Now I have a spare tucked away as a last case scenario
Jensen3
Louisville KY
2025 Maverick Lariat
To program a new key without FDRS you need 2 keys already programed to the vehicle.
Remove the liner in the bottom of the center console.
You will see a indentation slot to place a key in there, its the back up slot in case the battery goes dead in the fob
Keep Foot OFF the brakes for entire procedure
Place the first programed key in the slot & press the start button
Wait 10 seconds & press start button again turning it off.
Within 10 seconds place second key in slot & press start button
Within 10 seconds place the unprogrammed key in the slot & press start button
You should see a message on the instrument cluster "Key Programing Successful" & the door locks will cycle
Excellent info. I have a '25 Lariat Hybrid which does not appear to have the indentation/slot anywhere visible. Anyone know how to add a new key specifically for the '25 Lariat Hybrid?
Did you remove the floor covering of the console so you could see the indentation?
Cancunbadlands
Cancun
Cancun
Jensen3
Louisville KY
I did. It's smooth with the exception of the wireless charger plate and a little access port that doesn't seem to do anything but show part of a wire harness and down to the floor. Wait, " floor covering of the console" are you talking about the liner farthest forward ahead of the shifter knob with the angle for a phone to prop up? If so that's what I described above.
Quest
Quest
open the lid of the center console, there's a fabric liner in the bottom you need to remove
A
Any picture of it?
Here this the fiber liner pic is on my hood.
Ford Maverick 2025 XLT remote start with Cheap replacement key fob IMG_20250825_165939
Ford Maverick 2025 XLT remote start with Cheap replacement key fob IMG_20250825_170101
It is the spot you place your fobs when battery in fob is dead to start your push button start and when making more keys.
ETA: mine is a 2022. Not a 2025 it could be different in 2025???
Cancunbadlands
Cancun
Cancun
I got it now! TY pal
Quest
Quest
Nope, same 22-25 with keyless
Keyed is an antenna ring at ignition cylinder
Cancunbadlands
Cancun
Cancun
Hopefully you did not buy the gun safe???
It might complicate things unless it has hole in its floor???
I keep it on my waist... #safety first
