2025 Model Battery Update?
Golf Mike
Michael
Nevada
2025 Ford Maverick with 4k tow package
Some software glitches, maybe but batteries are still the same and CV axles need some miles to really see.
20-30k miles is a sweet spot for those CV's to go.
Golf Mike
Michael
Nevada
I was having the same issue and i found 2 work arounds, 1) move the keys far enough so that the Maverick cant pick it up 2) turn off looking for updates on the mobile app. I had the issue put a full charge back on the battery and a week later it started again. Also note the first thing that goes out is the auto stop / start feature, when stop working its begun!
Updates on the FordPass app on your phone?
You probably mean something different.
If your non-moving key fob sitting too close causes a reaction in the truck - you have a bad key fob.
They are supposed to go to sleep on non-movement to preserve their battery life - they'd never make it long sending out signal 24x7.
You might do a test.
Fob lock doors after getting out.
Lay fob within the recommended distance of 3 ft on a table or shelf from front door.
Let it sit for 5 min.
Approach door and try to open with sensor.
The truck picks up a signal that is sent, not just a fob that is a sleep laying around.
REMOTE CONTROL LIMITATIONS
WARNING: Changes or modifications not expressively approved by the party responsible for compliance could void the user's authority to operate the equipment. The term "IC:" before the radio certification number only signifies that Industry Canada technical specifications were met.
This device complies with Part 15 of the FCC Rules and with Industry Canada license-exempt RSS standard(s).Operation is subject to the following two conditions: (1) This device may not cause harmful interference, and (2) This device must accept any interference received, including interference that may cause undesired operation.
Make sure a valid remote control is within 3 ft (1 m) from the front door handles and rear of vehicle.
The system may not function if:
  • The remote control remains stationary for about a minute.
