2025 HVAC?
Don806
Don
SE Ohio
I've noticed in my 2025, that the HVAC is on when the truck is started (not remote start) even when it was not on when the truck was last shut off. it was warm enough to not need the heat this morning so I turned it off on the way to work. When I went to lunch and started the truck, the heat was already on. Anyone else noticed this issue?
Don806
Don806
Don
SE Ohio
must just be an Ohio eruption green issue................:cwl:
mechgingeneet
Cameron
Indiana
2025 Ford Maverick XLT
Actually, it's also impacting Indiana eruption green Mavericks too...source: Me. 😂
Don806
Don806
Don
SE Ohio
so far it's limited to areas with B1G schools............LMAO
Ozarkbeard
If you have your HVAC set on Auto mode, next time you do use the heat, try changing the system from Auto to Manual mode.
SteveM
Maryland USA
2018 Silverado, 2025 Eruption Green Lariat Hybrid
Mine is not set to auto, but I have the same issue. Eruption Green Lariat Hybrid in MD.
23grayXLT84
Midwest
23 hybrid xlt
There should be no reason for climate to automatically turn on of it was left off during last drive unless you remote start.
Maybe this is a feature on the 25s under certain conditions it turns on otherwise I'm not shocked there are bugs in the it's been perfected over the years in other cars sync4 system :)
Don806
Don806
Don
SE Ohio
No remote start today and it was on when I started the truck. AUTO not on, and found nothing in the settings for it. On when we left Sam’s club, and again when we left rural king?
Captain DUB1
NJ
2024 XLT Maverick
On my 2024, the HVAC stays the same as when I left it. But if I remote start on a cold morning, it throw the heated steering and seats to max hot but retains my last temp setting. I wonder if there's a "smart" sensor to find the average it should be.
But then again IDK what software changes they may to the 2025. Sometimes its perfect and other times its too much. Overall pretty good IMO
TheWong
Nick
2025 Maverick Tremor
This happens to me in my 2025 Maverick Tremor.... Remote start with HVAC functions properly. but if i have the system off and go back and start the truck normally the HVAC usually always comes on no matter the temp outside.... kind of annoying.
710-oil-614
Cal
2025 Hybrid AWD Lariat
May or may not matter and it isn't 100% consistent for me but if I turn HVAC off with the fan and little 0-15 slider it tends to come back on when I restart.
If I turn off HVAC by swiping up and hitting the power button for it in the upper left corner it seems to keep it off better at restart.
TheWong
Nick
Doesn't seem like it matters with mine... I have turned it off both ways and the issue still happens.
identifyasatruck
Par
2025 Maverick Lariat AWD
i will give it a try. it started happening to me too. i know its not on Auto. the fan speed slider is set to 1 whenever i startup...turning it off is just another button to push.
1 push ok to seatbelt;
2 push ok to get to last drive mode;
3 push 4 buttons to get my cards back up on the dash;
4 push the parking brake button then the OK
5 turn the hvac off
710-oil-614
Cal
5 turn the hvac off
HAHAHAHA I love your user name.
