12V flex bed no power
Kizyle
Kizyle
Kyle
Ford Maverick XLT
The 12v on either side of the bed are on the same 20 amp fuse and when you turn off key they remain hot for the time delay period.
No voltage when key is on, fuse is good. No clue as to what to do. Unplugged the battery, unplugged and reconnected the harnesses. No idea what is next
Replace fuse any way? Might just look good?
Kizyle
Kizyle
Kyle
Ford Maverick XLT
CurtisB
2023 Maverick XLT Hybrid
Looks like its time to call in Forscan to the rescue. You probably tripped a code and this has caused the outlet not to work. I could be totally off base but you have tried everything else.
Kizyle
Kizyle
Kyle
Ford Maverick XLT
Ya that is what I’m thinking. Hoping dealer doesn’t screw me
Still no power, I got no clue what the dealer would do. So frustrating
Did that too lol. I don’t know how to trace it past the middle harness. This is driving me nuts
I found this in another thread
After I installed my bed lights, I went through the same issue!
solved it by turning the truck on and off! Didn't realize that the bed 12v pigtails would have ZERO power after they timeout and only gain power after the ignition is switched on again. Annoying and wasted a bit of my Saturday trying to verify my test light and multimeter were working! lol
Several threads reporting problems. I am guessing that since it's on the delay circuit then instead of blowing the fuse the delay circuit may have another fuse or more likely a circuit breaker that tripped and might have set a code which needs to be cleared. But who knows. One reported his dealer found a blown fuse he could not find. Good luck....
Grand Nat.
NYC/ L.I
Schwinn Stingray
If you have voltage when you turn the key on and start the vehicle and then turn the vehicle off the power could remain on for 5-15 minutes. Your system is working correctly.
BlueSpec1
Gene
I wonder if the BCM is keeping the power point latching relay Reset.
The diagrams for the relay show a Reset coil and a Set coil that the BCM controls thru a microcontroller on the BJB circuit board.
I've noticed mention of pulling off the battery for awhile to reset the BCM and that Forscan can reset a module.
I don't have a problem with mine, just wondering how there's no power to the bed if the 20A fuse isn't blown.
Ford Maverick 12V flex bed no power Power Point, Rear 12V Outlet, USB Charge - Latching Relays
Ford Maverick 12V flex bed no power BJB Micro Controller to Power Point Latching Relays via Chan04, Chan08
Kizyle
Kizyle
Kyle
Ford Maverick XLT
Yes I tried that, with no luck. I believe there is a “circuit breaker” in fuse box under the glove box. No clue on how to reset that. Only thing I haven’t tried. I pulled every 20am
Thank you for all the info. I am going to unplug the battery for a couple hours tomorrow and see if that makes a difference. I did like 15 minutes earlier today
Have you unplugged the drivers side pigtail and tested the passenger pigtail? Then the reverse? Do they work individually? I assume you have not hooked up any device to them yet? Those breakers may not be serviceable which means they have to be replaced???or if they reset then is possible the bcm has been told to ignore that Circuit until the dealer tech resets the error flag. I have no idea, sorry...
Maybe the issue is that the harness is bad?
To that end could probe for power at pin 3 on the C1035B connector that's on top of the underhood junction box. It's the one closer to the engine of the two. That'd narrow it down to the relay or somewhere along the harness itself.
