1,000 mile oil change w/a few pics
EMD_Driver
South Carolina
2015 F-350 DRW 6.7 / 2022 Maverick XLT 2.0 AWD
I managed to hit 1,000 miles today and decided to do my first oil change.
Ford Maverick 1,000 mile oil change w/a few pics IMG_2704
After watching Blake's FX4 oil change video, I was curious to see how I could pull the filter without spilling oil on top of the rear skid plate. You can't. Even if the truck were level and on a lift, the oil would still run on top of that skid plate. For reference, here's a pic from directly under the edge of said skid plate:
Ford Maverick 1,000 mile oil change w/a few pics IMG_2705
I can confirm that all of the 13mm bolts (2 on front and 6 on rear skid plate) have threadlocker on them. Interesting to note though... All of the T30 screws for the front plate were able to be taken off, using nothing but the torx bit. No ratchet was necessary. The screws on the bumper side are screwed into plastic, so I understand them not being as tight as the rears, but I could almost remove all of them with only my fingers.
I can also confirm, with only 1,000 miles on the oil, that @FORD BOSS ME was 100% correct about the strong fuel smell present in the oil on these things. I was also amazed at how dirty this oil was, after only 1,000 miles... Whatever oil is put in at the factory also looks like alien blood..
Ford Maverick 1,000 mile oil change w/a few pics IMG_2706
I buttoned everything back up, filled the oil pan with the prescribed amount of oil (5.5qts) and proceeded to run flood mode and fill the filter up. Worked like a charm!
I also got my Fram XG3614 filter today and decided to compare it to a FL-910S..
Ford Maverick 1,000 mile oil change w/a few pics IMG_2707
Ford Maverick 1,000 mile oil change w/a few pics IMG_2708
Ford Maverick 1,000 mile oil change w/a few pics IMG_2709
Ford Maverick 1,000 mile oil change w/a few pics IMG_2710
Looks like I found the right filter for the Pennzoil Ultra Platinum 5w-30 oil that I ordered. It will be here Monday, so I just used Motorcraft oil today..
Brian_J
Akron, Ohio
'22 HPR Maverick AWD 4K LUX
Strong fuel smell? That can’t be good. Did you idle it before draining? Maybe to warm the oil up?
I’m planning on changing my oil at either 2000 or 3000 miles. Maybe I’ll send an oil sample out to blackstone…
EMD_Driver
EMD_Driver
South Carolina
@FORD BOSS ME did a video, explaining why the 10,000 mile OCI isn't a good idea. He pulled some oil from a 2.0 EB engine and was commenting on the fuel smell. I was planning on doing mine at 1,000 and was curious to see what it was like and I found out. It's caused by the turbo boost and the compression, forcing small amounts of the fuel/air mixture past the piston rings and is normal. I get a faint diesel small in the oil of every diesel pickup I've ever owned.. That's high compression...
Also... I always change my oil when it's hot. I had just returned from taking my Father-in-law to the store..
Darksider
Here
Two
Fuel smell or oil dilution is a common side effect of a direct injection engine. Why I wouldn't go over 5k changes with DI. You can expect it to be normal for all of the eco engines.
WesM
Wes
Maryland USA
Wow I have never seen oil that looked like that... well unless it had water in it. That definitely makes me want to change the oil at 1k miles too when I get my truck.
tomahawk72
Travis
Westbrook, Maine
22 Maverick XLT
Does it look like this because Ford puts additives in the Oil for the break in period? I will definetly get mine changed at 1k now!
ffjack15
Jack
Kansas City Mo
Honda
I changed my oil at 1000 miles no fuel smell but oil does have a greenish color.
Brian_J
Akron, Ohio
Gotcha. I’ll have to look for the video when I have time. A UOA is cheap enough. That will shed some light on what’s really in the oil.
abjbrtd
TX
Hyundai Kona, Thor Citation
THANKS for this thread AND pictures!
I would be a nervous wreck if I saw oil like that coming out of my brand new motor :eek:
Did you make sure the gasket came OFF with the filter?
They've been known to stick to the block when over tightened
It's also good to see that Hulk Hogans twin brother is still hand tightening the factory oil filters :D
EMD_Driver
EMD_Driver
South Carolina
I did check and clean the filter mount. I should have taken a picture too.. Kind of freaked me out when I saw that the sealing surface was 3/16" larger in diameter, than the filter itself!
FORD BOSS ME
And even worse with boost
FORD BOSS ME
What camera are you using, amazing pics!
FORD BOSS ME
The Fram Ultra Filters down to 20microns at 99% efficiency and 15microns at 93% efficiency and 10microns at 74% efficiency
It's a terrific filter and filters better than the OEM one but the oem is the only other I'd use ATM
Shecster
North America
1930 Model A Ford - 1971 Ford Maverick
Yes
Also noted that the FRAM is made in the USA. I like both FRAM and Ford filters though.... both have served us well.
Draining the oil when the color is as shown.... no problem here for that choice. ✔🇺🇸
Happy motoring !
