Do you kind sharing what dealership you bought your Maverick from?Central IL
None of it applies to shipping really, not in terms of you tracking anything. GOOD LUCK with the shipping process going to RU2G! Expect for it to make it to Chicago pretty quickly, maybe a week, then it will bounce around Chicago for about 2 weeks then in my case (Chapman Horsham) it sat at the ramp for another couple of weeks.So my Lariat Hybrid (ordered 7/19) was "shipped". By Rail. On April 13. "Ramp One" is RU2G, which I take it is New Castle, Del. (makes sense as we bought from Chapman in Philly). On the top right of the window sticker (Monroney), after the VIN, is "NB" What is that (I thought NA meant USA shipping)? On the top left of the window sticker is "HRM-003619 PA 9-NORMAL,NB,003619,ND041 9738", some of which is in tiny letters. I get the "PA." Is any of the rest deciphrable?
Mine is on its way to Kansas city from Hermosillo as of 2 days ago. Yours sat there for 2 weeks before making its way to you? So I should probably expect the same and final devl to be pushed about a week?Same situation - mines been in KC since 04/06....However my dealer just called and said they are picking up a shipment of Mav's and Bronco's, and mine should be on the truck!!!!
It's really hard to say, mine was finally picked up and delivered to the dealer yesterday, so it sat in KC for almost 2 weeks. Thats just my experience, others have been shorter/longerMine is on its way to Kansas city from Hermosillo as of 2 days ago. Yours sat there for 2 weeks before making its way to you? So I should probably expect the same and final devl to be pushed about a week?
The only option without a VIN is to call your dealer or FORDHello, new member here and wondering if there is a way to track without a vin. Ordered 12/16/2021
thanks
Most of the rail cars hang around Chicago for about a week. Mine finally moved from Chicago to Ohio last night - headed to Baltimore (eventually). expected arrival to my dealer 03-09 May. Built March 25th,As a Canadian, none of these links pertain to me. Last info from my dealer was that it was in Chicago. I have my VIN and expected arrival to Manitoba 01-07 May. Cant wait.
Help me here but what does the 22627433 stand for?Try just calling this number (copy and paste the ENTIRETY into your smart phone):
(800) 235-2352,1,,22627433,,,302628,,,##
I confirmed it worked and the last update is that your train is in Columbus, Ohio today. Good luck!
Identifier for the rail car identifier, you can get this from your dealer and sometimes from Ford.see the Tracker tab above.Help me here but what does the 22627433 stand for?
Thanks!
302628 is the railcar identifier.Identifier for the rail car identifier, you can get this from your dealer and sometimes from Ford.see the Tracker tab above.
The rail car letter identifiers. For example if yours is "TTGX123456", the first part of the number that you quoted would be "81814192" instead because the letter "T" is the 1st letter on the 8 key (on a phone), hence the "81", the "G" is the 1st letter on the 4 key, hence the "41", and the "X" is the 2nd letter on the 9 key, hence "92". Then the following number on the chain that you quoted would be the rail car number.Help me here but what does the 22627433 stand for?
Thanks!
When you call in they ask for the alpha portion separate from the numeric, TTGX is 8849. I have been tracking mine for 2 weeks.The rail car letter identifiers. For example if yours is "TTGX123456", the first part of the number that you quoted would be "81814192" instead because the letter "T" is the 1st letter on the 8 key (on a phone), hence the "81", the "G" is the 1st letter on the 4 key, hence the "41", and the "X" is the 2nd letter on the 9 key, hence "92". Then the following number on the chain that you quoted would be the rail car number.
Different rail lines require different input. I tracked mine for 37 days successfully through CSX, BNSF, Norfolk Southern, and Union Pacific, so I had to learn through help from others how they differed. The automated line I referenced in the original comment was for only one of the rail company lines and will not work for them all.When you call in they ask for the alpha portion separate from the numeric, TTGX is 8849. I have been tracking mine for 2 weeks.
