Thank you, great explanations and now I understand 🙏can it really go nearly 25 miles on electric only
  • Thread starter Deleted User 24227
  • Start date
  • Watchers 23
Deleted User 24227
Guest
The image isn't mine I just saw it on the forum but I was questioning the accuracy of the display yesterday on my Mav after driving 28 miles and 14 of those showed as electric? I know I'm missing something, the Jeep E plug in gets about 20 miles on a charge, this isn't a plug in and it's getting more??
Ford Maverick Thank you, great explanations and now I understand 🙏can it really go nearly 25 miles on electric only Screenshot 2026-03-26 7.18.57 PM
d7602002
Joseph
2024 Maverick XLT
I can't say for sure if it's accurate cuz I don't have a hybrid, but you went 28 miles and got 14 on electric which is about 50% and if you look at his numbers he went 50 and got about 25 which is 50%. So at least as far as that goes it makes sense.
But I am also curious as to what the answer would be.
bgn
WA
No. The Maverick battery is tiny relative to the 4xe and plug-in hybrids. It requires the engine to kick on to charge the battery or regenerate charge with braking.
Deleted User 24227
Guest
I'm sure many here have gotten similar results but I'm also sure someone knows the true answer. Seek and you shall find, I'm seeking lol
Deleted User 24227
Guest
That's what I was thinking so what is the computer thinking lol
Ryom
PA
Yes it's possible and you're looking at it. The battery will regen as you go and provide electric propulsion whenever possible. That includes pure battery power and electric assist to the ICE, which reduces fuel consumption. A fully charged HV battery will get you 1-2 miles before depleting enough to start the ICE engine.
Ford Maverick Thank you, great explanations and now I understand 🙏can it really go nearly 25 miles on electric only 20251028_193318
Ford Maverick Thank you, great explanations and now I understand 🙏can it really go nearly 25 miles on electric only 20250904_083651
Hot Runr Guy
West Chicago, IL
Easy-peasy. Run out of gas 25 miles from a gas station and see if you make it,,,,,,,,
HRG
Deleted User 24227
Guest
That being the case why doesn't the Jeep 4xE with a larger battery do the same, they're lucky if they squeeze 20-23 miles on the charge.I will say I've had my mav for about a month and haven't refueled yet lol
Ryom
PA
Probably a heavy foot at high speeds in a heavy vehicle?
The hybrid battery is recharged some every time you brake or coast also when the ice is running sometimes.
Bobkath
Prescott, AZ
BMW Z4 roadster ,Highlander 24 pepper red hybrid
When I'm driving slightly downhill, or a steep downhill, and sometimes on a level road, barley using the gas pedal it shows electric power. Often it shows the distance and how much was electric. Have not seen 50%, but some 35% to 40%.
Wahjahbvious
Don't Worry About It
Erf
'26 Hybrid Lariat in a color that seems to anger the dumbest people you know
Weight, aerodynamics and engine.
It's a shame the 4xe has turned out to be such a turd. It's a strong idea and if they'd pulled it off better, the phev Gladiator would probably be out by now. And then we'd be off to the p(ickup)hev races!
