Wireless charger stops charging after a few minutes.
Aparadox
california
NA
In case anyone has experienced the same issue: my wireless charger on my lariat would not charge my phone all the time. I am using an iPhone mini and I put a rubber mat over the tray to keep it from slipping around. However I began to notice that whenever I place my phone in the tray, the wireless charger would only work for a few minutes, and then I can see that the phone stops charging. I have to pick up the phone and then put it back to reactivate the charger. This is very annoying. Is there anything that I can do?
The Weatherman
Dean
KY
Aparadox
california
NA
Remove the rubber mat. See if that helps. Do you have a thick case on your phone? This could cause the problem.
Mine phone does not have a case and I would try removing the mat, thanks!
Indy300
Palmetto, FL
Maverick Hybrid Lariat Lux
Mine does the same. It usually gets extremely hot and the iPhone says it stopped charging until the temperature goes down.
Hum, so far mine has been working flawlessly, hope it stays that way.
Bret Grabber
DeKalb, IL
2024 Maverick Lariat (Grabber Tribute)
I have an Otterbox cover on my phone that has saved it more than once from drop damage. I noticed it would heat up to the point of shutting down charging and wondered about the thickness of that case interfering with the charger. Sure enough, when I took it out of the case, it got warm but never hot. Problem solved!
Betting that rubber mat is impeding the charger.
