Wipers when they’re in the Park position
Vomamansr
gary
Long island ny
I need help from my fellow Maverick owners. The question is on the wiper blades when they’re in the Park position does the passenger side wiper disappear completely or does it stick up a little bit? Mine appears to stick up. I feel that it should go down further. what’s everybody thought on that?
Ford Maverick Wipers when they’re in the Park position imag
Jeff D.
Duluth, MN.
Mines sticks up slightly, too, like in the pic. I assume that's normal. 🤔
commadorebob
Just checked my Lariat and appears to be about a quarter inch lower than yours. I think that is likely margin-of-error stuff.
AzureBlueBill
Torrington, Connecticut
Can't go down too much more; it'll be hitting that rubber thing in the corner.
Oh, and mine looks just like that too.
BlueSpec1
Gene
The tips of my wipers are over the dots in the glass.
They're harder to see depending on the light.
Ford Maverick Wipers when they’re in the Park position Maverick 2.0L Wiper Dots
Jeff D.
Duluth, MN.
That's about where mine is too.
Ford Maverick Wipers when they’re in the Park position 1000001350
I agree with Commadorebob. If you look at the windshield there is a small line mark in the glass to show the approximate spot the wiper should be in park position.
Kagiso
Patrick
US
2001 Toyota Tacoma PreRunner
Mine park like that too. There's plenty room to have designed them to park below the hood line. 🤷🏼‍♂️ I've accepted it.
PRH
Robert
Canada, Ontario
I feel like they should park in a more "parked/lower" position but I've studied many of them as I come across and it seems like they are all like this. Mine included
Brianx
Pennsylvania
'24 Eco Boost XL Cactus Gray, tow bar, Co-Pilot
one can always replace a wiper blade with a shorter one, not that it would solve much.
BeardedK
Kevin
22 Maverick XLT
Might not have been aligned correctly at the factory? You can adjust it by removing the arm and setting it lower. I had to adjust mine after having my windshield replaced, takes about a minute.
Tim d
Alpena
Ram
If it bothers you, you can pull the wiper arm off the post,turn it a bit counter clockwise and reinstall.
Jeff D.
Duluth, MN.
As a person who lives in an area that can get alot of snow, and have had vehicles with wipers that retract alot lower when turned off, I think I'm ok with where these park.
I've had the others not be able to retract fully, or even close to where they were supposed to be because of snow packed in that void, and I've always worried that it wasn't good for them to be that way. 😳
I wondered, "Is the motor still trying to retract them?" "Are the arms getting tweaked from the stress of not retracting fully" "Is the wipers linkage getting damaged?" 🤔
dldjtad
Bartow, FL
2023 Ford Maverick
To my knowledge, this is normal
raymaines
Ray
Tacoma, Washington
Alto Blue Lariat Lux Hybrid
Why would you feel that your truck would be different than all the other trucks that have been sold in the last three years? You're entitled to think there is a better way of doing things, but why would you think FORD would single you out to do your wipers wrong?
