Wiper Blade Specs
gsglassm
Greg
New Hampshire
2025 Oxford White LOBO, 2025 Ford Bronco, 2007 Honda Element SC
I'll say it again. Save yourself some trouble, time, and money:
There is an easy way to get the right ones. I've been ordering from Aero Wiper Blades for several years now. These are high quality and have worked well for me in all seasons. Oh yeah, just $20 for the pair! Just tell them the Make/Model/Year and they'll send you the correct ones. Aero Wiper
2025's are not listed on the Aero Site.....
colinl
Colin
ICT
yeah, that can happen. but they fit, nothing changed with the wipers.
pick 2022 or whatever.
betlouboo
Bette
Medora, IN
26 Ford Maverick Hybrid
Driver's side is 22" and passenger is 21". I saw some Michelin wipers cheap at Costco, so I bought a set. https://www.costco.com/michelin-beam-wiper-blade-guardian.product.4000179786.html
I quickly realized that they're more than 1/2" shorter than the OEM wiper blades. They work great, but I think I know part of the reason they're cheaper!
While annoying, the shorter blade changes literally nothing on the driver's side and on the passenger side the unswept area is not in an area I look out of much, anyway. That's why it's unswept right? LOL.
What adapter did you use?
colinl
Colin
ICT
that was 2 years ago and I replaced those wipers last year, so all I can tell you is that it was the one that fit.
may I presume you found this because you have these wipers and can't install them? the adapter is definitely included and I recall having to take some piece of plastic off to use them.
if you don't own those michelin blades, or you can return them, do it. use these instead: https://www.amazon.com/dp/B0BQ6HBRVV?th=1
they were previously mentioned in this thread as well. I just installed my second set of blade inserts, so it's 2 replacements for $22. we had record rain this spring and summer, otherwise I think I would have gotten more than a year out of them. I've never ran my wipers on max speed as much as I did this year.
Gee, I purchase and use the higher priced Rain-x (stronger strength?) Washer fluid. I am running my 2022 maverick since 3rd week of Jan 2022 and have not reversed the rubbers yet so going onto 4 years. I do wash bug hits as they happen so they don't dry on windshield. Keeps the rain-x "refreshed" on windshield. Water beads and rolls off in light rain so wipers don't even have to be turned on until rain intensifies some. I do run on intermittent frequently so blade has some water to wipe and furnish lubricant.
betlouboo
Bette
Medora, IN
thanks says for 2022-2023 mines a 24 still 22 & 21 should fit
colinl
Colin
ICT
redputter
Edward
Cedar Falls
2023 Ford Maverick Hybrid
I've bought the Trico Ultra and those have the correct adaptor for the Maverick.
I saw this earlier in the thread but never a resolution: my original OEM wiper blades were 23" and 21", but RockAuto (and apparently most other places) specify 22" and 21". I wish I measured my blades before I ordered them.
Hot Runr Guy
West Chicago, IL
I ordered the Motorcraft # WW2249 from RA this morning, I'll confirm if it's actually 23"+ like some claim.
I'm thinking the Bosch Icon 24OE (24") should fit with no problem.
HRG
Hot Runr Guy
West Chicago, IL
HRG
it's exactly 23" long.
HRG
ZH84
Kentucky
The motorcraft is listed as 22" but if you measure it, it's actually 23". Even the Rock Auto specs say it's a 22" blade but the item length is 23". From what I've found so far, no one else who make wipers with the Maverick style connector offers them in 23", it's only 21" and 22" then jumps to 24".
Not really a huge deal, you're getting basically a half inch less on each end of the wiper blade. You'll probably never notice a difference
