Where does the water drain with tonneau cover?
Mightybeast
Adam
Oklahoma
Maverick hybrid
Tanneau Cover on the bed where does the water goes and drains? Any pictures?
Scupking
2025 Ford Maverick XLT Hybrid
Some will get into the bed but the bed has drain holes in multiple places. To me its not a big deal. Keeps stuff mostly dry. I never expected it to be water tight.
lonewoof
Rob
2024 Maverick
Like this;
HRG
Is this factory setup or your awesome homegrown solution? That's the factory roll-up tonneau I think, right? Pretty neat idea - how effective is it?
Hot Runr Guy
West Chicago, IL
That's my self-installed BakFlip Mx4 tri-fold. Can't tell you how well my drain works, as there is occasionally some water under the cover.
HRG
Toddman45
St. Louis, MO
Most hard tonneau covers have drain tubes that most use a OEM grommet in the bed for the drain tubes to go through and then the water drains just above the rear wheel wells.
Usually there's two to four holes drilled in the rails the cover sits on to allow intruding water to run in that channel and drain out the rear tubes close to the cab.
Ford Maverick Where does the water drain  with tonneau cover? 17358606824783517377236086883454
Ford Maverick Where does the water drain  with tonneau cover? 17358607393815977849953343975553
Ford Maverick Where does the water drain  with tonneau cover? 17358609104558867610008177256185
buck 013
Neal
2024 Maverick Lariat 2.0l AWD
I need two of those grommets, anyone know part number?
Backin15
Frozen Minnesota
2025 Maverick XLT
I have a hard rollup cover, it is actually more watertight than I expected. Due to the fact that there is no gap between the bed and cab, and the front lip is a bit lower than the side rails it will probably leak at the front. My leakage has been limited to the corners though, and the water just drains away. I do have a bed rug, but the water goes right through it and is not absorbed.
Joe Strummer
Squamish, BC
2024 Ford Maverick XLT Tremor
My Dealer installed Ford branded Tonneau cover has no drain pipes/tubes. Personally I can't see how two super tiny tubes can drain a lot of water, given their location.
I have some vague memory of drain tubes being required for spray in bed liners.
Wahjahbvious
Don't Worry About It
Erf
'26 Hybrid Lariat in a color that seems to anger the dumbest people you know
imboden013
West Memphis AR
2024 & 2025 Mavericks
I like that. I'll try and rig that for my tri-fold.
I installed a hard trifold on my sons XL and I cut little small X’s in the grommet just above those in this pic. Before I installed the cover I used silicone to fill to body seams next to window and two channels where the two pieces of bed cap came together. I waited a few days and trimmed silicone flush with razor blade then I installed cover so there was about 3/4” gap between back window and cover. He’s driven through a monsoon and had a tiny bit of water at the tailgate.
