Wheels spacers
ahallock
Allan
2026 Maverick XL
Has anyone used wheel spacers on your Maverick? I have 2026 Maverick XL and have new wheels with a +40 offset and I am concerned about rubbing. I have new 235/65/R17 AT (Ridgecrawers) tires to replace stock tires. I have standard suspension.
xample81
will
Pennsylvania
25 Tremor
I run 18x8 +40 on a stock tremor with no rub and a 30” tire
BK007
BK007
OH
If you do run them just make sure they are Hubcentric and put Blue Locktite on the lugs of the spacer. I ran them on an F150 for years no issues at all!
Hot Runr Guy
West Chicago, IL
The 2.5mm difference (1/10") is not enough to cause any rubbing, even with the 235-width tire.
You don't need spacers.
HRG
Sticks
St. Louis
Here's a fitment calculator so you can measure for yourself.
Offset has little meaning without a width measurement, but it's probably fine unless you're adding a huge spacer.
I run 17x7.5 +35mm with 235/65 A/T's and 32mm spacers. It narrowly clears at full lock with OEM suspension.
Mox4615
Jeremy
NC
2024 Lariat
If you buy any you have to get at least 25mm to prevent having to cut the studs. I run 25 fronts and 35 on the rear.
Robot-Wrangler
Kentucky
I have run the Mach-E 20" wheels with +47.5mm offset and 255/50R20 tires. My wet weather set is 17" Maverick steel wheels with +37.5mm offset and 245/65R17 AT tires. You should be fine.
