? What thread is the antenna?
Cruzer01
2022 Ford Maverick XL
.50 Cal antenna here working fine.
Ford Maverick ? What thread is the antenna? IMG_20220404_193136220
AF Blue
US
NA
I'm not that opposed to plugging the hole
**EDITED - removed mention of "Standard 10-32" value and image as @Ottocycle mentioned it is not the same **
Hope this info helps .. was searching for "antenna thread" to plug mine.
Visited the local Lowes and got what I needed.
Note:
- i did cut the flat head machine screw a little more than half.
- M5-.80 (x16) was too long. If a x6 was available, i would have used that to avoid cuts.
Metric = M5x0.8
Ford Maverick ? What thread is the antenna? 1692649631544
Ford Maverick ? What thread is the antenna? 1692649792360
Ford Maverick ? What thread is the antenna? 1692649853575
Ford Maverick ? What thread is the antenna? 1692649895089
coyotewr.x
Conner
Yuma
'22 BajaMav
Note:
Metric = M5x0.8
Standard = 10-32
Note:
Metric = M5x0.8
Standard = 10-32
This is awesome, thanks for the information. Looks great I’ve been wanting to do this to mine. I’ve just been running antennaless.
Ottocycle
Baja Georgia
23' RS6 Avant, 14' CTS-V Wagon, 87' BMW 535is
10-32 is not equivalent to M5x0.8. The thread pitches are slightly different with the 10-32 being slightly finer vs a M5's 31.5 threads per inch. You will gall the threads. For something like a brass threaded antenna it won't matter as brass is self lubricating, stainless and steel yes.
ejouie
Evan
Newnan, GA
'23 Ford Maverick, Atlas Blue, FWD, EcoBoost, XLT
I use this: https://a.co/d/1oyMhqr
Ford Maverick ? What thread is the antenna? PXL_20230406_112344543
I don't use that antenna at all though as I run everything from my phone. Reception seems to be poor, but easy enough to put back on the stocker if need be.
AF Blue
US
NA
Thanks for this info ... i did not know ..
It did not feel like it was the "wrong fit" when i tried it.
I will edit my post to mention just using the metric value.
AF Blue
US
NA
Same boat...don't use radio, but use my phone as well for everything.
I like all the stubbies I have seen in this thread .. just preferred to plug it for < $4.
I put the OEM antenna back in the glove box in case i need it for some reason.
