What is best for beach driving - FX4 or Tremor?
This RDU in the Focus RS definitely overheats with hard use. I know it can be done on a road course and there are RDU cooling kits on the market to help mitigate overheating.
What I don't know is if someone has done it in a Maverick Tremor and what circumstances caused the event. I know it seems like I'm just arguing semantics, but here are a couple of good videos, you'll probably appreciate the complexity and sophistication in the Tremor RDU a lot more.
Cutaway Focus RS RDU (same/highly similar as Tremor)
Can't find a video on the Dana rear end Ford uses in the Bronco and trucks, but this Eaton is essentially the same just beefier.
The biggest usable difference is that the locker does nothing for cornering or straight-line traction - no torque vectoring or limited slip. It is just an open differential when the locker isn't engaged. Whereas the Tremor RDU is very active in cornering, and very active at maintaining traction. It isn't a locker, but it's better than a locker for most conditions Tremor owners will encounter.
Pee Dee
NC coast
several
I can't speak to the Tremor's capabilities but my initial impressions of the Fx4 with the optional Wildpeaks is that it does pretty well as long as you're careful to stay out of deep ruts from other vehicles, due to the limited ground clearance. I keep a shackle hitch receiver under the back seat so I have a good recovery point in the rear, just in case.
Bwicka
Lakeside,ca.
I'm guilty of getting riled up in defense of the Tremor just as much as those defending the FX4 - we're a fickle bunch.
Beach I'd mostly agree but if you're hitting any sand dunes and hooning around with PTU locked over hot sand that is where I would expect it to possibly disengage.
You’ll be fine with either on the beach , carry a 30$ compressor air down to 18 lbs you will go absolutely anywhere most people on this forum will dare.
go tremor if you wheel a lot , especially big dune climbs and mud ( liquid cooled to being the biggest advantage for longevity)
if you want the tow capability more than off road capability and longevity in either direction …. Your choice .
Bwicka
Lakeside,ca.
Pto cooling is what I was saying … hate auto correct..
710-oil-614
Cal
2025 Hybrid AWD Lariat
Yep, OP would be fine with a Hybrid too.
OP asked which was best and the clear answer is the Tremor for the reasons I stated.
FX4 does nothing to enhance the AWD capability of the AWD maverick (I know you know this)
Reece @ DI
Reece @ DI
Reece
McAllen Texas
2022 Ford Maverick XLT Hybrid
I appreciate it! Beach driving is something pretty new to myself, maybe a little daunting as well. While I say "beach driving" I'm talking bare minimum. I'm not looking to do anything crazy, just a nice beach day with the family, possible beach fishing, etc. I've heard that I "could" use the hybrid, just wasn't too confident in that.
Thanks again for all the help here guys!
AlsMaverick
Allen
Cincinnati
And who said it did?
garryjohnson
Garry
Pensacola, FL
Ford Maverick XLT FX4 Atlas Blue
While I can't speak to the Tremor's capabilities (I'm sure they are great), I can tell you that the FX4 is a very capable soft off road vehicle. Case in point, I was at my gun range the other day and I had my target set at 50 yards. My range is pretty much all red Florida sand and there was plenty of deep sand there. After I was done shooting, I was too tired to walk the 50 yards to retrieve my target stand (I'm 69 years old and way out of shape) so I drove my FX4 to the target. I set the drive mode to sand and had no problems, even with the deep sand. I was kind of proud of my little FX4 Maverick although I'm sure my previous XL AWD Maverick could have done just as well.
Tremor1942
Phil
Pennsylvania
2023 Maverick Tremor
According to these guys the rdu does NOT overheat on the Tremor
TheShark
The best for driving on the beach...my Bronco! 😁
Ford Maverick What is best for beach driving - FX4 or Tremor? 1E1462B0-C79D-494A-BFEE-B58FB57C34D4_1_105_c
Montana
Best for beach driving?
Tires. Tires. Tires.
Airt down and carry a shovel/something to place under the tires for grip. Then it doesn't matter what you drive. FWD, RWD, 4WD, AWD... they should all do just fine with the right tires (assuming you are smart enough to stay away from the quicksand).
Pee Dee
NC coast
several
It looks like you have the Falken Wildpeaks, which would make a huge difference in sand compared to the standard Fx4 tires.
garryjohnson
Garry
Pensacola, FL
Yes they are indeed Falken Wildpeaks. When I ordered my '23 Maverick I made sure to get the upgraded wheels and tires.
