Str8Jacked!
Colorado
Ford maverick
IMO these are better than the OEM floor mats, these go much higher and actually go up under the pedal, which will catch all mud, water and snow from your gas pedal as the OEM do not cover this area. I realize this is for a safety hazard im sure, however I wanted the extra coverage.
AndrewSKY117
Andrew
Olympia, WA
'22 Outback Limited
Maybe I shouldn't have gotten them for $175 and gone with Weather Tech instead, I do like the idea of more coverage being on a job site all the time that's pretty dirty. Did you have both of them? I haven't seen the physical difference, but now I'm curious. I will probably end up getting a set. Thanks for letting us know!
Str8Jacked!
Colorado
Ford maverick
Hey, yes I did have both of them. I didn't think to do a video when I had the others.
I returned the OEM ones to get these. The OEM ones are still really nice quality, it just came down to the coverage for me.
vezpa
EMG
IL/IN border
Too many to list.
The problem with WeatherTech is they usually don't go up the firewall very high on the driver side corner where you would put your foot, on the flat part. That is the part of the floor that takes the biggest beating. Husky has always been my go to on all of my vehicles because of this part of the design which can be seen in the photo below. Husky seem to hold their shape better as the edges of the WeatherTech seem to roll down over time.
Ford Maverick WeatherTech floor mats installed hqdefault
Str8Jacked!
Colorado
Ford maverick
Ya that's a great point, I like husky liners alot and had them in my last car with no problems and solid build. Husky doesn't make them for the Ford Maverick yet unfortunately so I went with the weather tech over OEM.
Rob Cactus Gray
Robert
Sierra Vista AZ
11 Prius
I also got weather-tech for coverage and price.
Retiredguy
2022 Maverick,2021 Ford Bronco Sport, 2020 Ford Ec
I believe Weather Tech makes liners for the front only.
AndrewSKY117
Andrew
Olympia, WA
'22 Outback Limited
This is great to know! Thank you.
710-oil-614
Cal
2025 Hybrid AWD Lariat
Have gone back and forth between Husky and WeatherTech for years and I have to say I think WeatherTech are slightly nicer and the price different is minor these days.
You make a valid point on the Husky coverage but the are a thinner and harder plastic/rubber material than the WeatherTech.
WeaterTech will be purchased ahead of taking delivery of my Maverick. They will be dropped in before the test drive and bring it home.
Air Shootist
IL
Fully loaded 2022 Maverick Lariat
I ordered the factory all weather mats as an add-on where they also included the factory carpet mats. I only received the front carpet mats.
Should I have received rear carpet mats?
maxpaine1337
South Carolina
F150
Does Husky make a set yet for the hybrid maverick? I don't think they do...I usually stick with husky weather beaters for everything.
Aminal
New Jersey
None
According to Kristen B. of Husky customer service, they'll have Maverick mats in late January.
