Unexpected interior wear
Clarkdonbran
I must get out of the car like I get out of bed on Christmas! Damn.
Ford Maverick Unexpected interior wear C61E7760-B56C-4E49-BE97-C8ED29939B9D
Flight Test
DFW
Corvettes
There are seat belt buckle condoms available on Amazon.
Clarkdonbran
Clarkdonbran
That’s definitely a search item to delete afterwards! I’ll check it out. Thanks!
Stuart
Stuart
Las Vegas
Maverick on order
Has anyone tried 303 automotive protectant? Seems like the coating would allow items to glide off, without damage to the surface
KenT
Ken
UT
2018 Honda CRV
Did you notice that the light blue trim piece right of the radio and around the a/c vents are crinkled, like a piece of paper balled up then flattened out again.
Deleted member 5352
Guest
If there was one main gripe I have with the Maverick it would be this. The interior plastics are very, very, very, scratch prone. Even looking at it too hard will cause it to scratch. That's why I'm very careful when getting in and out and touching stuff too much. And if I do have to touch something, I have a soft, velvet microfiber cloth to dust everything with. I understand that this was a budget oriented vehicle to keep the price down but even at $35,000 you'd expect some better wearing interior materials. I still love the design and textures used throughout. I think it's one of the coolest interiors out of any budget-priced vehicle right now but it's too bad it scratches so easily, especially on the b-pillar where the seat belt buckle is, the trim around the seats, the lower door panels, and the door sills.
Deleted member 17191
Guest
Has anyone tried 303 automotive protectant? Seems like the coating would allow items to glide off without damage the surface
I am using 303 on all my surfaces. Using Aerospace 303 Surface Protectant on the plastic specifically for a low sheen and the feel. It isn’t preventing scratches, but it does diminish their appearance.
i have an additional wear spot developing low on the B-Pillar from rubbing. Making a thin protective strip with an inexpensive cutting board might be the best route. Heat to fit and attach with a temp adhesive.
Mavonorder
Pete
Camry
I don't think it's a question of cheap materials, more like the texture is supposed to be stylish, but it backfired and the texture is too grippy so when something hits it, it "grabs" and scratches it.
Plus, the hatch pattern blue interior pieces are generally located in non contact areas like high on the dash, etc.
jtpc2021
Oklahoma
eh, I’ve seen Porsche Caymans with color wearing off of interior plastics, which is bad when your interior is tan and it wears to black underneath.
A few scuffs on dark blue plastic of a $21-$31K truck won’t hurt as badly as interior issues of a Boxster/Cayman.
But either way, I feel the plastic will hold up over time, even if it has some scratches. 🤷🏼‍♂️
