Transmission fluid - Drain/Fill - Fun
Nw_adventure
Salt Lake city
Got to 25k and had to do the Auto trans fluid change. Highly recommended - The OEM fluid was pretty gross - This is a relatively easy procedure - Replaced the engine oil as well . Cheers - Do they use chocolate milk when doing the first fill in Mexico ? 🤣
Ford Maverick Transmission fluid - Drain/Fill - Fun PXL_20250111_001803363
Ford Maverick Transmission fluid - Drain/Fill - Fun PXL_20250111_002026881
Packer Bill
South Dakota
How did you remove the old fluid...did you pump it out?
Nw_adventure
Nw_adventure
Salt Lake city
Easy drain plug - Fill requires the air box to be removed. Not hard. No pump needed like the PTU -
Richard2212
Indiana
2020 Fusion , 1984 Mustang
I change mine every 5000 miles to to avoid the "Chocolate Milk". Engine,PTU,RDU as well. (AWD)
Nw_adventure
Nw_adventure
Salt Lake city
Wow that's an aggressive schedule - I did RDU/PTU fluid swaps after seeing reports of factory underfilled quantities and wanted to see for myself what was up, got that handled @ 18K-
Richard2212
Indiana
I drive this vehicle 5000 miles/ year. Cost $200. or less at home.
NY DIY GUY
New York City
www.youtube.com
23 Lariat AWD Black W/BAP, LUX, 4K
If you do it from the bottom you only have to remove the drain and leveling plugs. I used one of those fluid bottle pumps to pump in the fluid from the level plug hole. I did it on a lift which helped a lot. Did my initial drop at 12k and fluid was still good but you could see it had some wear to it. Used about 4.5 bottles to fill it back up.
Nw_adventure
Nw_adventure
Salt Lake city
Good to know. Can u access the leveling plug without removing the wheel ? I got 4.5 out but put in a full 5 quarts since my vent has definitely burped out a few times and I am unsure of how much fluid they actually put in at the factory knowing the RDU/PTU have been under filled in quite a few instances.
Richard2212
Indiana
When I drained my Trans I Collected and measured the fluid removed. It was 4.5 quarts. I replaced 4.5 quarts.
Other owners have added fluid until some came out of the Level plug - they used 4.5 quarts.
Anything over 4.5 quarts is overfill.
I also purchased a Dorman dipstick to confirm my levels before and after.
Nw_adventure
Nw_adventure
Salt Lake city
When I drained my PTU I Collected and measured the fluid removed. It was 4.5 quarts. I replaced 4.5 quarts.
Cool- If mine feels bloated I am sure it will burp - I guess it will never be known how much trans fluid these actually ship with- I lost a least a few ounces of fluid over the course of two years (small puddles below the vent tube ) from vent/burps/etc- Assuming this is caused by high/heat/elevation/off-road fun- etc.
Equator Guy
Topsham, ME
2023 Maverick XL., 2015 Rav4. 2012 Suzuki Equator
Hello: Can you please post a link or the part # for this Dorman dipstick? I have seen references to it on this forum, but never a part number. Thanks!
Tbone289
I think you mean transmission, right? The PTU and RDU both hold less than a quart of fluid.
Carlitos_92
I was able to put just over half a quart in each of mine - meaning I can't use the 12-14 oz I have left the next time, and have to buy fluids again anyway. Genius on Ford's part. :D
Tbone289
I was able to put just over a quart in each of mine - meaning I can't use the 12-14 oz I have left the next time, and have to buy fluids again anyway. Genius on Ford's part. :D
Assume you mean just over 1/2 a quart? :wink:
Oh well, you can use some of your leftovers on the second refill...
Carlitos_92
Oh well, you can use some of your leftovers on the third refill...
Yeah. My math is gooder than my spellung.
