Trailer Hitch Adapter For 2024 XLT
2024 Ford Maverick
Hello all,
I just installed a trailer hitch on my 2024 XLT Maverick and discovered that they don’t provide the plugin for the 4-pin connector. So I ordered the whole wiring setup. I’d really like to use the OEM 4-pin because my hitch has the recess for it and it has the closing lid. I’m wondering if there’s some sort of adapter to connect these two pieces in the picture together or if I’m going to have to do some wire splicing. Thanks in advance!!
Ford Maverick Trailer Hitch Adapter For 2024 XLT IMG_8625
Hot Runr Guy
West Chicago, IL
I know of no off the shelf adapter available, I'd just splice it with weatherproof butt splices and call it good.
HRG
Carlitos_92
Is the thing on the left not the 4-pin plug that goes on the trailer side? I don't know why Ford would make that, but who knows.
The tan connector plugs into a harness on the truck. Not sure it exists if your truck did not come with a hitch originally.
2024 Ford Maverick
Yeah, that’s the problem I’m having is that my truck didn’t come with a plugin for the OEM connector. So I had to buy an aftermarket assembly to wire it all up. I want to use the OEM connector rather than the 4-pin that the wiring assembly came with because it can slip into the recess of the trailer hitch and is a little more durable feeling and looking.
AutobahnSHO
Will
S.Carolina
Maverick, Miata
I would return that wiring and gab the Curt adapter.
You have to run a power wire but otherwise it's pretty neat with no wire hacking.
BlueSpec1
Gene
Without the OEM harness wiring from the Trailer Tow Module to C401 female connector up under the bed, better to use the Curt Adapter as mentioned.
OEM C401 with 4 pin wiring:
Ford Maverick Trailer Hitch Adapter For 2024 XLT 1760989869079-q5
Ford Maverick Trailer Hitch Adapter For 2024 XLT 1760990199872-nr
C401 Molex MX150 connectors
Ford Maverick Trailer Hitch Adapter For 2024 XLT 1760989743120-3
Molex connectors smiliar to OEM in harness: 33472-1207 Female, 33482-6202 Male.
Molex GREY 12 Pin Wire Connector, Harley Waterproof, Sealed Kit, MX150
Hot Runr Guy
West Chicago, IL
Great minds think alike! Since I have the female terminals already, I ordered a couple of the light gray "B" housings earlier today, I have a box of 4-flat trailer plugs. I'm pretty sure he already has the Curt harness, and I understand his desire to use the OEM socket/door in the factory bracket.
HRG
