TPE Hood Protector
BouseBill
AZ
2024 Maverick Lariat 2.0L 2024 Expedition Limited Max 2020 HD Trike
Purchased in Dec 2024, did not last 2 years in the Arizona heat and sunlight. I've tried "back to Black" and Armor-All to no avail. The material seems to suck up the liquid protectant but by morning it's back to ugly. I'm going to remove and replace with paint protection film. More expensive yes but it should last.
BK007
BK007
OH
https://www.amazon.com/dp/B0CZML4B6B?psc=1&ref_=cm_sw_r_cp_ud_ct_B66JDRWNTS1RP20C1V45
I used this on a family member's Maverick after someone scraped the rear bumper, and it worked perfectly. It's a dye, so it actually penetrates the plastic, unlike the other products you tried that are just for shine rather than fixing sun damage.
Tip: Clean the surface first with a 1-to-2 ratio (1 part 70% alcohol to 2 parts distilled water). Also, applying a ceramic coating on top helps a lot! Definitely worth a shot. A little bit goes a long way. Good luck!
  • Like
Reactions: Dad
Cancunbadlands
Cancun
Cancun
Replace it with OEM Ford hood deflector
It's great quality
KO Stradivarius
The Disputed Lands
'25 XLT
I live in AZ as well, "The Disputed Lands", if anyone here is familiar with the TV show "Brockmire", starring Hank Azaria. It is so good...I think it's on Netflix now. Four seasons.
https://en.wikipedia.org/wiki/Brockmire
https://www.imdb.com/title/tt5722190/
But I digress. The AZ sun is a "worthy adversary". I have to park my Mav outside and I don't want to get a black tonneau/bed cover or bed mat because I don't want to fight the AZ sun. It fades and degrades just about everything, it's just a question of when. White colored vehicles (like mine) are VERY common out here. So many white pickup trucks!
asylus
George
TEXAS
'24 Ford Maverick Lariat Tremor
I agree with the better quality one from Ford. I got mine on a discount and have been happy with it over a year with no issues.
Chaseman17
Chase
Pennsylvania
2015 Mustang GT
Solution finish or Cerakote Trim coat. The only options that actually work to restore trim and are semi permanent for a couple of years.
BouseBill
BouseBill
AZ
Thanks for the replies, I'll be visiting my son next week, he's the mech in the family so we'll see what he thinks.
Paint it. What do you have to lose?
BK007
BK007
OH
I have used SEM Trim Black it works great!
Find A Distributor View Resources
Trim Black
Part #39141
Trim Black is an acrylic coating formulated to match the OEM finish on automotive trim components. For use on plastic, aluminum, steel, stainless steel and chrome.
Tech Data Sheet
Safety Data Sheets
Features
  • Excellent adhesion and durability
  • No primer required
  • Matches OEM appearance
  • Retains flexibility
  • Great coverage
  • Professional results
More Features
(3) options available
Trim Black
Part #39144
Details Videos Resources Related Products Find A Distributor
Applications
  • Plastic
  • Aluminum
  • Steel
  • Stainless Steel
  • Chrome
BouseBill
BouseBill
AZ
OK, Folks here is the final result for the Chinese hood protector:) As stated above my son is a 30+year helicopter tech. His suggestion was to use the SEM Trim Black, so that's what we did. The results speak for themselves. After washing twice with scotch brite and a good grease/oil remover then wiping down with alcohol we covered the little "Nanny" truck with plastic and proceeded to paint the hood protector.
I'm happy with the end result but the real test will be how well the SEM Trim Black holds up the Arizona desert heat and sun.
Damn that came out nice.
Only time will tell how it lasts. 🙏
BK007
BK007
OH
Nice work looks great! I have had very good results with SEM Trim Black over the years.
Cancunbadlands
Cancun
Cancun
Nice move!
Maxzina
Diamond Sponsor
New Jersey
Hello,
If you encounter any fading problems with the tpe hood protector, please feel free to contact us at any time. You can send us the order number via PM, and our after-sales service will handle this issue. And our manufacturer informed us that the cause of the chemical reaction has been identified and is gradually being tested.
Similarly, spray painting is currently a temporary solution to this problem.
