Totaled or not?
Totaled or fixable?
  • Total voters
Gvmumbral
Gerardo
Pasadena, CA
Honda Element
Saturday night i got hit by a dumbass Challenger driver.
You all think this is totaled?
Fudge, just found another part of the body-on-frame tat is damaged; I circled them.
Airbags did not deploy.
22 Hybrid XL
Ford Maverick Totaled or not? 20241102_192251
Ford Maverick Totaled or not? 20241102_192216
Ford Maverick Totaled or not? 20241102_192205
Ford Maverick Totaled or not? 20241102_192232
Ford Maverick Totaled or not? 20241102_192310
Ford Maverick Totaled or not? 20241102_192242
Ford Maverick Totaled or not? 20241104_104619
Bwicka
Lakeside,ca.
Kind of close because of door jam sheet metal , but since no airbaigs or seatbelts , probably in the $14-12k range .if miles are not too high , probably a fixer upper.
carlsgt
Carl
2025 Maverick Lariat
Sorry to see this. I voted fixable hoping the frame is still in tact. Being forced to replace is a big economic headache.
Dudley
Doug
Indiana
2003 Grand Cherokee
I voted fixable also thinking that rear door sill is not damaged enough to harm the integrity of the unibody. If it had been below door, well ....
Superg0
2024 XLT FX4 Azure Gray
Doesn't look that bad, however, I'm no insurance adjuster.
Egz
Fredericksburg, VA
2022 Maverick Hybrid Lariat, 1967 Fairlady
Normally I would say fixable, but I don't know how an insurance adjustor would view the damage to the sill.
dusty1787
Dustin
Wisconsin
2023 Maverick EB Lariat
I am not a repair tech or insurance adjuster, but in general it looks fixable. Like some others have said, I bet it will be costly, but fixable. But at the same time insurance could just say "screw it"... and that's that. One of those "repair it will cost 20k, and vehicle worth 22k... here is your check for 22k".
On this site there have been a couple rear end fender benders that just barely bent the frame and had less damage to the tailgate than your back door shows, and yet it ended up being "totaled". And at the same time some members had damage repaired with no issues....so i would suggest start thinking good thoughts! But I feel it should be repairable unless they dig deeper and notice other issues that are not as obvious.
Toddman45
St. Louis, MO
I'm going to guess fixable coming in around 15,000 or just slightly less. But as others mention I'm not an insurance adjuster and some would rather total it than bother fixing it.
James K
NY
2022 Maverick,1960 Bugeye, 1973 GT6, 2016 R1200GS, 2024 KLX300
22 Hybrid XL
Did you drive it after? If you did and it tracked straight (hands off wheel), then maybe. It's difficult to tell from photos. Even if it pulls slightly, it's possible that it was knocked out of alignment slightly but it needs measurements to determine if frame suffered.
Gvmumbral
Gvmumbral
Gerardo
Pasadena, CA
Honda Element
I drove it fine. Didn't pull to either side. Drove it both on the freeway and on side streets and it was driving normal
James K
NY
You have a reasonable chance for repair then
Mareys
Mary
2022 Maverick Hybrid XL Area 51
22 Hybrid XL
OUCH! So sorry to see that. People need to pay attention too many senseless accidents
Ozarkbeard
I'm not a body shop tech or insurance adjuster, so I didn't vote.
If you want to get it fixed, what I would do is get multiple estimates, if someone tells you it's totaled. Make sure you ask about "diminished" value, when negotiating a payment.
