Tire Pressure
Mikeysd
Michael
San Diego
Maverick Laiat pepper red Lux package 2022
Has anyone on here notice that what you tire pressure says on instrument panel is different than when you use a tire gauge? My inside would say 30PSI and when I get out and use the tire pressure gauge it's a 33 or 34. I don't know what one is right.
jsus
2022 Ford Escape Hybrid AWD
Your mileage may vary. Some have found the TPMS pressure readings from the car to be more accurate than others.
If you trust your gauge, then go with that. That said, I've had some cheap digital gauges that themselves weren't very accurate.
Mikeysd
Mikeysd
Michael
San Diego
I'm just using a reg tire gauge and it was on point when I used it on my last car.
Scott Asheville
Scott
Asheville, NC
XLT Lux here. I keep wondering how people get tire pressures from the gauges. I've read all the threads on the subject, also read the manual, and I still can't find the TPS page. I follow the steps - no TPMS option anywhere. I have had the TPMS warning page with pressures pop up once - so I know it's in there. I access it with no problem from the FordPass app.
Mikeysd
Mikeysd
Michael
San Diego
I have a lariat Lux and from the settings on the right side of your steering wheel you can scrool in the menu and you will find the tire pressure and it will show all 4 tire pressure
desmobob
Upstate NY
2022 XLT EcoBoost tow package, 1995 Ducati 900SS SP, 2025 CF Moto CF500
Use the steering wheel "OK" button to scroll through your instrument cluster display screens by pushing it up or down instead of in. Go to the screen that shows a Maverick, then click the "menu" button, then scroll to "information", from there, you'll find the tire pressure screen option.
jsus
This is the way for those without Lariat or FX4. It’s also where you’ll find things like the seat belt minder screen and auto start/stop status for EcoBoost.
Penasco
2019 Outback, 2005 Tundra DC
I frequently utilize the very convenient free tire check at Discount Tire near where I shop. Their machine shows the same pressure as the instrument panel in my Lariat.
Scott Asheville
Scott
Asheville, NC
Thanks I'll try that on my next drive. I missed the part about changing menus by pushing the OK button instead of just toggling it up down. This reminds me of a human factors book I once read called "Don't Make Me Think". Really, that was the name of the book. I think they used the term "affordance" for features that don't require what I call "secret knowledge". I find if funny that the word "Ford" is in that word. Generally Ford does a pretty good job of making things obvious.
https://www.merriam-webster.com/dic...perty of,those affordances are fairly obvious.
https://en.wikipedia.org/wiki/Don't_Make_Me_Think
Scott Asheville
Scott
Asheville, NC
jdetterb
Ford Maverick XLT Hybrid
This has worked fine for me for nearly five months. Then two days ago, I put additional air in my tires. Now the tire pressure screen option has disappeared from my menu. I can still see the readings via the FordPass app, but no way to see it via the instrument cluster anymore. This is bizarre. Any ideas?
desmobob
Upstate NY
How bizarre...
I think there is a way to customize the menus so you can de-select some items to save you time scrolling. Maybe you did this inadvertently?
Montana
lol how much air did you put in?
But it sounds like it got removed accidently. You can go through the menu and select which screens you want active.
jdetterb
That is what I was thinking. But I've spent the last four days going through every option in the manual and the menu, and I still haven't found an option to toggle displaying/hiding the tire pressure screen. At this point, I'm thinking it is a system glitch and I might have to ask my Ford dealer to try to fix it.
Does anyone know where in the XLT menu you go to toggle displaying/hiding the tire pressure screen?
MoveOver
Jan
Rockville
I had the same issue and the tire pressure option was kind of hidden, because it was scrolled away. If you see the trailer sway control, scroll up and it will go to the section where you can select the tire pressure monitoring. Once selected ( I think you can select only 4 options), you will be able to select/see the tire pressure on the Maverick display.
