Tailgate cables - should both be taut?
porto
tony
Wa
2025 Maverick
I have a 2025 Maverick AWD --when tailgate is in down position both cables are engaged and taunt, however when the tailgate is put in the halfway position only one cable is engaged and taunt --the other cable is loose - thus only one cable is holding weight of tailgate? The Dealer states all 2025 Mavericks are designed this way????? Is this true?
RDRahn
Cleveland OH
Pictures would help, but no, each side should be connected the same way no matter what at least for my 2022. Can't imagine 2025 models are different.
I've actually figured out (with help of this forum) 4 different ways to "string" the tailgate cables for different tailgate heights.
AZ-Mike
Michael
Glendale, Arizona USA
2025 Maverick XL
I just noticed this last weekend with my 2025 AWD XT. I think with tailgate fully down one cable is a little more taught than the other, but at halfway position its a significant difference.
I would love to understand the reasoning behind this if it is supposed to be this way.
tic105
There should not be a major difference between the cables at either position. Sure, there may be some minor difference in the tautness of the two cables, but when some weight is added, there is enough flex in the gate that both cables should be taut.
In the down position, sit on the tailgate - both cables taut? Then add some weight in the 1/2 way position and check tautness.
Dave O
New Smyrna Beach Florida
Only a few physical things that could cause this IMO
Cables are slight different lengths
Anchor positions on the tail gate the truck bed are slightly off
you can measure all of these to verify and rule this out
NedF
BC Canada
I must be getting to old… I can only figure out 3 ways to string the cables to achieve different tailgate heights? It was my younger brother who showed me how you can loop the cable from the bottom connector over the top one to get the higher position right before he told me about the built in hand warmers in the tailgate for when I had to push it in the winter. Apparently he is not a FORD truck kind of guy.
porto
tony
Wa
2025 Maverick
I
porto
tony
Wa
2025 Maverick
This is what I have
Ford Maverick Tailgate cables - should both be taut? IMG_2933
Ford Maverick Tailgate cables - should both be taut? IMG_2934
Hcopter
KS
You may be able to loosen and slightly reposition the latch pin(s) so that the cables are both tight, but this will also affect the position of the tailgate when closed.
RDRahn
Cleveland OH
I’m away from home for a couple weeks. Will take some pics (if I remember) when I get back.
NedF
BC Canada
This is what I have
I remember being slightly concerned that I might have the same problem while I was waiting almost a year for my truck but was happy to find they were both exactly the same length. If I had this problem and because I am a tiny bit OCD I probably would have sought a solution from Ford and barring that bought replacement ones from Ford in the hopes that I could find at least 2 the same length from the 4 cables.
dalola
Retired
SE Ohio 🇺🇸
lol... what a moron....I hope he was joking.... 🙄
RideSolo
Cory
North Central Ohio
I will admit to being somewhat OCD at times but I'm not sure why this is a problem, especially one that's so important that one spends time thinking and worrying about it before their ordered vehicle arrives.
NedF
BC Canada
LOL, I assume you are replying to my post... maybe you did not see " slightly concerned " (slight-ly {adverb} 1. to a small degree; not considerably). I was not obsessed with it, but I would think any weight limits of the gate are determined while being suspended equally from both sides and not from one cable on one side. I am glad to hear you would not have worried about it.
