Stolen Catalytic converters
scotty
pompano berach fl
dodge caravan
Couple trucks, not mavericks had their CATS stolen this past weekend. Guy had a tundra they say off the cats (2)
probably in about 10 minutes per truck due to the liberal space under the tundra.
Wondering if there is an undercovering/shield that is below the CATS to discourage someone from
going under the maverick to cut out the mavericks. I know there is a shield that has to be removed
to change oil, but didn't know if it extends to the CAT area.
Are there 2 CATS under the maverick
Clarkdonbran
I believe they are prohibitively hard to reach.
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
Ten minutes? Try 30 seconds each, at least the ones who are good at it.
If you want to protect them there are a few solutions, depends on what is available in your community. Some companies wrap them in thick metal cables with barbs on them that wear out grinder wheels/reciprocating saw blades quickly. Others install plates on the frame.
StillWaiting
Brandyn
St pete
2009 Dodge Challenger SRT8
The hybrids have them up near the engine by
scotty
pompano berach fl
dodge caravan
thank you. if there is the shield below the CATS then i am convinced that there are too many
other CATS out there that would make it easy to remove vs maverick.
Are there 2 cats in the hybrid?
