Speaker removal and sizing
Natulv
Levi
Thornton Colorado
2022 Maverick, 1967 ihc 908b
We will begin with the front doors. There are 2 7mm screws in the bottom of the door, 2 underneath the window control(pull up at the back end, as it slides in at the front so pull-up and slide back), and one 8mm hidden behind the door handle (black plastic piece pops off). The door speaker appears to be 6 3/4, part number and such on the photo. To get to the tweets you need to pull the white plastic A pillar cover, which is held on with standard pull clips and an elastic. Be cautious not to screw up the airbag. Once that piece is off you can pull the speaker grill from above the tweet, and the tweet itself is clipped on with 3 prongs around the cone. The back speakers are a royal pain. First tip the seat forward and remove the plastic piece that goes around the middle passenger seatbelt (yes all the way across as it holds down part of the c pillar trim, luckily it's only held with light clips) . Next remove the dark trim piece below the light piece the speaker is on (again just clips on this one, pull). The c pillar trim will have one screw near the bottom, toward the door side, should be 7mm or 8mm. Once that's removed, while gently pulling out toward you on the cpillar speaker assembly, lift it up a bit (the clips are in a slot and WILL NOT PULL without breaking unless the assembly is pushed up to align the wider part of the slot, ask me how I know it'll break). These speakers are held to the plastic trim itself, and appear to be 4s . All model and speaker photos attached to make it easier to cross reference. This is on an xlt, not the lariat or b&o upgraded stereo. Hope this helps some of y'all. Oh yeah, the door speakers have a shallow 1.5 inch to fit into depth wise, otherwise the run into the window track brace, so either mount out with a spacer or find a slim speaker.
Ford Maverick Speaker removal and sizing 20211022_170648
Ford Maverick Speaker removal and sizing 20211022_175517
Ford Maverick Speaker removal and sizing 20211022_175710
Ford Maverick Speaker removal and sizing 20211022_175707
Ford Maverick Speaker removal and sizing 20211022_175046
Ford Maverick Speaker removal and sizing 20211022_175228
Ford Maverick Speaker removal and sizing 20211022_172547
Ford Maverick Speaker removal and sizing 20211022_172535
Ford Maverick Speaker removal and sizing 20211022_172901_HDR
Ford Maverick Speaker removal and sizing 20211022_171808
Ford Maverick Speaker removal and sizing 20211022_170844
Natulv
Levi
Thornton Colorado
You are my new hero! Thank you for this
Np, just glad to help. Those c pillars are a pain to remove. I busted the 2 plastic holders cause I didn't know they had a slot
Brian_J
Akron, Ohio
'22 HPR Maverick AWD 4K LUX
4” rears is kinda depressing. Might be a little less expensive at least. Now to see how the cool kids add some bass.
Thanks for writing this up.
supersecretTB
Taylor
Buffalo
Thanks for the post I've started installing a system in my truck too. I have some questions for you. Do you know where the stock amp is located? Also, Any clearance issues. I will share my results once I'm all done.
Brian_J
Akron, Ohio
any way to determine the wattage of the factory radio? Since the speakers seem to be rather at 25 watts, I’m guessing it’s pretty low.
SgtLip
Donald
Disney World
2021 Lexus ES300h Ultra Luxury
Awesome. I'll take this to the Sound Dealer to see when I upgrade mine. He might appreciate this.
TheShark
Don't know if the front speakers are exactly the same as in the Bronco Sport but I'm guessing they are, PowerBeats makes a direct fit speaker replacement OE652-FD Coaxial and OE65C-FD. I replaced the OEM $3 speakers in my Bronco Sport with these, front and rear were the same 6.5" speakers, what a difference. The speakers mounted right in the OEM mounts and plugged right up. Got them on Amazon for $99 a pair.
TheShark
I can verify that the front speakers are the same as the Bronco Sport.
Ford Maverick Speaker removal and sizing IMG_2478
Nw_adventure
Salt Lake city
How much better are the speakers in the B/O upgrade ?
TheShark
Brian_J
Akron, Ohio
I believe someone posted the ford p/n for the speaks a little while ago. Same p/n as base radio.
edit: here’s the info Link. Looks like I’m incorrect.
hikonhui
kon
San Francisco
tundra
Did you use any sound deadening materials when you had the molding off?
TheShark
I did not on the Bronco Sport, just mounted them in the stock mounts.
Headdead
Birmingham, Michigan
Boxster S
Thanks a ton for the info. Can you elaborate on the rear C pillar upper trim: which direction are you pulling? Toward the hood ( F/A) or toward the opposite side (cross car). And you pull UP at the same time?
