snow plow or front hitch
Old Man
Nebraska
2023 Lariat
Give up. You already said you don't know if it can be done. You've been told over and over - no.
Give up.
rlhdweman
Random Lake Wisconsin
You would not put a plow on a Maverick anymore than you would put one of the front of a minivan, it's best just to pay someone to do the job who has the equipment, it's much cheaper in the long run.
coolrunning
rockland
ford maverick 2024
Cheaper? A company asked $200 to 4inch $50 every more inch, each time they come...
If in a month smow 10 times 5 inch , will be 2.5k... cheaper!
coolrunning
rockland
ford maverick 2024
Ford Maverick snow plow or front hitch Screenshot_20230718_195630_Acrobat for Samsung
CTYankee
Central MA
2022 Maverick XLT
I have a electric start snowblower. Bought 4y ago , used the first one , the second we had no snow. Used the third one , when went to start it , it didnt. Took me 5h to figure why. And it was a small grain of sand into the carburator nozzle that stuck the gas.
Imagine had to been crazy 5h for a little grain of sand.
Last winter i had like 9inch of snow and didnt used.
The snowblower I suggested isn't electric start, it's fully electric (battery) so no engine or carb or gas to worry about. I'm tapping out now. Good luck.
Hardening2753
Ford Maverick Hybrid
hello everyone ,
i would like to have an info ,
i have read that the maverick isnt made for snow plower ,
i have ordered the 2024 model , still it the same ? or they changed something ?
i just need to plow my driveway and my parents driveway , nothing crazy .
i have seen that they made small snow plower for front hitch , is that possible install the front hitch ?
last question , i also have seen the rear plower for the hitch , the snowsport 180 utility plow , anyone have tryed ?
thanks a lot
No change from 23 to 24 so no front plow
Hardening2753
hello everyone ,
thanks a lot
Were you able to come up with a solution?
coolrunning
rockland
ford maverick 2024
I have found the rear plower
2 solution that i have to check
One is the snowsport 180 , but is a fix rear plow that can only push , will be a little bit hard to maneuver and complicated near doors.
Second is the boss drag pro.
Is an idraulic plow , that can push and pull. Only problem is the weight.
I sent an email to the company to have more info about it.
Senior Master Ford Guy
99 Ranger, 04 and 18 Escape, 2023 Maverick Lariat
Since you have received nothing but " NO" and " not recommended" and " not built for it" answers with great information and explanations as to why not to plow snow with a Maverick and continue to search for the answer you want to hear, here you go: go ahead and put a plow on it, see if I care!! :ROFLMAO:
coolrunning
rockland
ford maverick 2024
Nothing can ne mount in the front , we got it.
Cannot be used to plow street , we got it.
But if i can hitch 4k trailer , there is no reason to attack something in the rear to pull and push few inch of snow.
Trailers aren't regularly for the use of colliding with and pushing stationary material.
mav_kev
PA
Mav
That rear mounted plow is about the dumbest contraption I've ever seen to move snow.
And what about a front hitch ?
Still void the warranty?
Does exist a front hitch?
Anyone have tryed the rear plower?
A front hitch would require a base plate for flat towing to provide a cross member across the front to restrict compressing and expansive forces from affecting the front of the unibody. The plow would most likely exert more forces than just the flat towing the base plate would be designed for resulting in it having to be modified/redesigned.
As for a rear plow it would require several sacks of cement in bed to add weight for rear wheels and the hitch is welded to the crash bar which is designed to crumple. It most likely be ok but if maybe not if you plowed a chunk of ice frozen to the cement. Any bending or damage resulting from bending would most likely not be covered by warranty.
