Service interval
Donaldw
Donald
Oakland, CA
Forester, insurance pmt. from stolen tacoma.
Our 23 alt is low milage. About 13,600 now. Last december at last service is was 12k. Our service dealer, one we really like not the one we bought from, says service at 6 months or 5k miles whichever comes first. My question is that accurate for low milage Mavericks? Longer time if less miles? Many thanks, Donald
El Kabong
Carnation, WA
Methinks the dealer is overselling you on service, yes lower miles = longer intervals (up to one year is specified in my '26 owners manual). So with your low mileage it should be once a year! You can always do it more frequently but it's not usually necessary with modern vehicles and lubricants.
So what does your owners manual say? If you take a lot of short trips, follow the "severe service" schedule, for example for my model year (2026) it mentions to changed the air filter every 30k miles and the spark plugs every 60k miles for "severe service" but does not mention severe service items for things like oil changes.
The manual also mentions that 1 year is the maximum between oil changes, otherwise to follow the oil minder when it comes up on the dashboard.
This is for a 2026, you have to check your own owners manual (you can find it online in your Ford Owner account).
"Intelligent Oil-Life Monitor™
Your vehicle has an Intelligent Oil-Life Monitor that determines when you should change the engine oil based on how you use your vehicle.
By using several important factors in its calculations, the monitor helps reduce the cost of owning your vehicle and reduces environmental waste at the same time.
This means you do not have to remember to change the oil on a mileage-based schedule. Your vehicle lets you know when an oil change is due by displaying a message in the instrument cluster display.
The following table provides examples of vehicle use and its impact on oil change intervals. It is a guideline only. Actual oil change intervals depend on several factors and generally decrease with severity of use."
VOL1
Bond
Atlanta
2026 Ford Maverick XL Hybrid
The real answer is “it depends”. In the grand scheme of things, oil changes are cheap. Most motor oil manufacturers suggest only going a year max, and that is for high quality synthetic oil. The oil itself not bad necessarily, but you need to consider water and acids that form over time, especially in rarely used vehicles. Direct injected engines and Hybrids both have challenges brought on by low use.
Use a very high quality synthetic and change once a year if you rarely drive it.
Me, because I plan on keeping mine a long time, I change more often, but that gives me piece of mind.
They are overdoing it considering it's a hybrid.
So little mileage I'm guessing more city than highway - so more EV than straight engine use.
Even for the ancient thinking of 3k changes with ancient oil and old style engines - you may have even less than that on the engine when 5k rolls around on the tires.
And this engine doesn't need 3k by a long shot - and today's oil easily good for a year.
