Screenside Dash Cubby Dimensions?
dogie rider
Frank
2019 Hyundai Kona
Would someone who has gotten their Maverick please provide accurate dimensions for cubby. Thanks
Updated with dimensions / measurements by @Delzona
Ford Maverick Screenside Dash Cubby Dimensions? alto-blue-8-25-cubby-1-
Ford Maverick Screenside Dash Cubby Dimensions? alto-blue-8-25-cubby-2-jpg
Ford Maverick Screenside Dash Cubby Dimensions? alto-blue-8-25-cubby-4-jpg
Ford Maverick Screenside Dash Cubby Dimensions? lariat-alto-blue-7-jpg
dogie rider
Frank
2019 Hyundai Kona
I would like something more accurate so I can build a custom insert/drawer that would fit snugly in it.
SgtLip
Donald
Disney World
2021 Lexus ES300h Ultra Luxury
@dogie rider
Sorry. I've seen 2 or 3 posts with a tape measure. Best you'll get before getting your Maverick to use your own tape measure on.
dogie rider
Frank
2019 Hyundai Kona
You may be right, but I'm hoping someone else may have plans similar to mine.
Delzona
Tucson, AZ
I have some pictures of the cubby with tape measure that can give an idea of the dimensions, however because the cubby tapers down towards the back I wasn't able to an accurate measurement. If you want the pictures just let me and I can either post them or PM them to you.
dogie rider
Frank
2019 Hyundai Kona
I appreciate the offer, but I don't think that will give me what I need. I want to build something that fits snugly in the hole, so I may need to wait until I get my truck as SgtLip said.
sabar
2022 Maverick Lariat
Dimensions are difficult on it because it is an odd shape, with lots of angles and bevels. My tentative dimensions with my calipers are: 57mm width, 84mm height, 75-78mm depth (tapers from bottom to top on a concave radius from feeling around in there).
I hope to have better dimensions of the cubby after some trial/error 3d prints. I don't have the tooling to measure this precisely (you'd need a good set of gauges).
Delzona
Tucson, AZ
Looking forward to seeing what come up with.
dogie rider
Frank
2019 Hyundai Kona
Thanks a lot for the measurements! That gives me a much better idea of where to start. I look forward to seeing your updated dimensions.
sabar
Small update -- 57mm x 85mm nearly perfectly fits the front. I'll mess with some slightly larger prints to see what a good depth is.
Spot
Dubuque, IA
VW Passat, Audi A4
I'm really curious as to how this project is going.
I plan on 3D printing a coin drawer that is similar to what I have in my Audi now. The Audi drawer is 20mm tall, and the length & width of what you are mentioning seems reasonable to work with. With the remaining height, I may be able to build a second drawer or just leave the rest as a doored cubby.
At any rate, if you could post your status on this, I would certainly appreciate it.
Tundra2Maverick(?)
Bruce
Maverick Hybrid Lariat Base Grp 500A
Any updates? So far I have seen a Kleenex Holder and Phone Mount in the cubby. I would prefer a drawer or door as described above.
bombast
Pennsyltucky
2022 Ford Maverick XL, Hybrid
I want to make a little coin tray for in there as well. I got a cardboard template cut that seems to be the right size. Modeling a flat plate in TinkerCAD now, will have it printed at work on Wednesday. If its accurate, I'll try to update this thread then.
Problem seems to be it tapers on both sides at different degrees. My current template only tapers on one side - Hoping that's enough to get a tight fit. Whoever drew the dimensions for this thing at Ford is a dick.
