jtpc2021
Oklahoma
I use the phone screen in conjunction with Apple CarPlay...especially for Waze, I can have the reports ahead on the phone screen while having the map and my music on the dash screen.
Pretty sure Apple doesn’t work that way, so you must be using an android? Carplay is all or nothing. Carplay also has split screen so you can have waze, music, etc up on the car’s screen at the same time, so no need to have phone in conjunction.
SantaStephen
Stephen
Chicago
www.santastephen.org
GLE, Disco II, Corvette
Running Carplay on my iPhone 12, haven't had an android since Jelly Bean. I use the splitscreen for Waze and Music but use my phonescreen to display the upcoming alerts. Do it this way in every car I've had that has Carplay.
SantaStephen
Stephen
Chicago
Don't have a spare phone to take a pic of it mounted, but here is a screenshot of both screens taken at the same time to give you an idea...
Dashscreen showing Apple Carplay
Ford Maverick Dash cubby phone holder mount installed carplay2
Phone Screen showing additional info from Waze
Ford Maverick Dash cubby phone holder mount installed carplay1
jtpc2021
Oklahoma
Oh, I see. That works then! 👍🏻
Sylvester
Ford
This is how Im using my cubby hole. I use this same magnetic mount in all of vehicles including work truck and boat. For under $8 it’s hard to go wrong.
my only advice is to make sure the truck and the mount are warm before sticking on
I just installed it and already regret it. It takes away from the OEM look of the truck and I think I did the mistake that I have it not far enough out and probably not in the right orientation (can only tilt down). The phone fits and points just forward. I didn't like it. Is it difficult to remove? What is the best way to remove with least amount of damage?
MaverickAngler
MaverickAngler
Andy
Tundra
I’m still happy with mine
From past experience removing things I’d suggest getting some fishing line behind it and pull. That should do a pretty decent job removing the holder. Then if there’s residue left I’d personally just rub it off with my finger.
you might be better off waiting until it’s a colder day and it might make it come off that much easier. Usually I’d say hot day but I feel like this stuff would do better in the cold
Sylvester
Ford
Thank you! I am still undecided. The metallic part behind the phone with protective film came off so I attached the other metallic plate lower, which makes the phone fit better. I guess I will wait and see, can always remove it.
clavicus
If you have a hair dryer that should make the adhesive schmooze enough to peel it off. Although some adhesives for mounts like dashcams can be extra strong and may be more physical effort. Some people use fishing wire to sort of cut those off and then scrape whatever’s left carefully and then use alcohol for the bits left.
RookieBlue7
Georgia
Maverick XL
Anyone have a favorite magnetic mount that also allows wireless charging? I think in my iPhone the coil is relatively centered, so that means either an open-ring-style metal stick-on for the inside of the phone case, or a horizontal metal bar stick-on that is either/both above and below the coil?
I use a Spigen MagSafe mount. It is a magnetic charger. I’ll have to figure out how/where/what base to use to mount it in the Maverick when I pick it up tomorrow since I’m buying an XL and won’t have wireless charging without it
JASmith
Jessica
Dodge Ram 1500
This is pretty cool buuuuut what's the point if your plugged in with carplay anyways? I've never used carplay/aa but wouldn't you get notifications and such on the 8" screen?
Ok this is the route I went. It’s much more expensive but I utilize this quad lock for my motorcycle so I have the case already. About $50.
Now this little rubberized tray was removed, I think the adhesive will work better directly to the hard plastic.
For that mount, I would try sticking it to the cubby that is on top of the radio, rather than to the right of it. That way the phone would sit more flush with the car screen. Use the side cubby for something else, like a garage door opener. Just my 2c.
clavicus
I ended up using a qi magnetic mount that I already had, and put the head on a different mounting platform. It seems they all often share the same standardized ball joint. Using the mount linked below still gives you the cubby to use for… trinkets…
Last pic doesnt show the qi magnetic head attached but it is what I have on there now. It’s not sold on amazon anymore but there are plenty more like it if you wanted to blow the money on an extra mount to mix and match.
Ford Maverick Dash cubby phone holder mount installed D4B5EE3C-2BEA-47E6-BF9C-72B9BB1F985D
Ford Maverick Dash cubby phone holder mount installed 2A0E63CB-4E73-4AA1-95D9-23004A00C28D
Ford Maverick Dash cubby phone holder mount installed E595351A-955E-406D-A07C-06F1014CB0E4
Ringke Power Clip Wing Magnetic Car Mount Phone Holder Premium Air Vent Cradle 360° Rotation Long Reach Neck Cell Phone Automobile Cradles for Universal Smartphone
RookieBlue7
Georgia
Maverick XL
That’s what I
That’s what I did with the spigen in one vehicle, I put it on an iOttie cd slot mount. I was afraid it wouldn’t fit but it did. As long as I can find a ball mount that fits the cubbie, that’s where mine will go.
Gconk
G
Alaska
Lots of Fords
Ford Maverick Dash cubby phone holder mount installed Screenshot_20220202-192141_DuckDuckGo
Yall stay distracted with your phones, that cubby is going to be for my main homie...
clavicus
For that XL adaptive cruise control, “jesus take the wheel” edition
Mas280
I added my phone mount with wireless CarPlay.
Ford Maverick Dash cubby phone holder mount installed FB811776-C1C9-4695-95AB-C008AB79CAE6
Ford Maverick Dash cubby phone holder mount installed 22E6EDA5-80B7-4C1B-BBE9-BC0B2B0B87D5
