AgerNymph
Eugene
US
2022 XLT EB, FX4
Used some plastic gutter guard installed in front of the intercooler to protect from road debris. Nothing fancy. Cut to size, folded and inserted behind grille. Used zip ties to hold in place. I had to repair once because of bird damage.
To clarify the bird damage was to the plastic mesh, not the intercooler One hit a corner and broke a zip tie.
Ford Maverick Road debris protection for intercooler Mesh
olddevildog
2024 Cactus Grey EB XL
Interesting idea. I will have to consider doing that myself. Thanks!
Tim d
Alpena
Ram
Used some plastic gutter guard installed in front of the inner cooler to protect from road debris. Nothing fancy. Cut to size, folded and inserted behind grille. Used zip ties to hold in place. I had to repair once because of bird damage.
If that's in front of the intercooler doesn't that defeat the purpose of it? Am I not seeing this correctly?
todd92
Todd
I own 5 Ecoboost Ford's and never had an intercooler damaged from road debris, but whatever. You're also reducing the airflow through the intercooler.
WNYEscapee
TJ
BFLO
2023 Maverick, 2019 Cherokee
I've had the same concern. Especially since during winter I tend to sometimes plow through a fair amount of snow. I'd thought of this idea, have plenty of this mesh in the basement too. I was hopeful that someone would have produced something a little more fitted and rigid, but this looks like it should work just fine.
Grand Nat.
NYC/ L.I
Schwinn Stingray
Despite of what you might think that little bit of mesh will increase the temperature of the engine. The purpose of the intercooler is to keep the air charge as cool as possible and keep the cylinder temperatures down to support boost.
Darklyter
FL
BASE
On my old Dakota I used the metal version of that.. was originally intended to use as 'mesh rain gutter protectors'. Same install- zip tied to the back of the grill.
It's harder for me to do this on this truck with the grill but I'll get it eventually..
Ford Maverick Road debris protection for intercooler Screenshot_20240401_175759_Home Depot
Mox4615
Jeremy
NC
2024 Lariat
I’d be surprised if it really made that much of a difference especially at cruising or highway speeds. Just my opinion obviously. That piece of mesh still has pretty decent size holes in it. Now if he was using window screen or something I could see that being more of an issue.
The bird pulled a "zippietiedie"!!!!
Montana
It's a surprising amount. The bigger the mesh the easier it is on the temps.
I was pretty shocked to learn how much of a difference the mesh in front of my PC fans made. The wrong kind basically makes fans pointless.
The one OP shared is reasonable and a great solution without sacrificing in temps but that red one likely increases temps. Without monitoring software we'd never know until it's too late. The longer that fluid runs hotter the shorter the lifespan.
Honestly though I feel like they don't do this because it's just a cost cutting thing. They'd rather replace a radiator than spend the extra pennies for protection from the factory.
ychuck46
Chuck
Crossville, TN
F-150 Supercrew w/EcoBoost engine, Maverick Hybrid
My concern as well. It is open for a reason.
dogtruck
Ken
Charlotte
2023 XLT
The mesh (as posted) may in fact deflect some cooling airflow.....but a lot less than some of the aux lights and led light bars our fellow drivers have installed to much acclaim.
