I'm not a car guy, but something that the Cuban Redneck said makes sense about why the cover is there. Aluminum doesn't like rapid temperature swings, and having the cover there keeps road spray off of the engine when it's hot. If the aluminum engine block is cooled too quickly (or unevenly cooled by chilling the bottom while the top stays hot), aluminum is prone to cracking. So, keep that cover on, ESPECIALLY in the winter when the road spray could be near freezing slush.
As far as sealing it. Cuban Redneck did his, but I'm not sure if that is the right thing. If it is sealed (especially for those of us in the northern climates) it won't soak up road-salt spray and become logged up with salt. But if it isn't sealed, any moisture that gets to the top side (water, oils, etc) won't seep through and drain out. It is porous for a reason. I just don't know if the reason is to let fluids on the top soak through and out, or the porosity is just a side effect of the materiel used.
