Recalibrate speedometer for larger tires?
Blueox76
Winona, MN
Ford Maverick Lariat, Ford Taurus, Ford Ranger
Is there a way to change the speedometer to account for larger diameter tires?
Johnkn
MD
What size tires?
If going from a 225-65-17 to a 235-65-17 within the same brand/family for example, the speed difference at 60 MPH is only ~1 MPH and hardly worth a change......
matmondro
Mathieu
Vassar, MI
Yes, using Forscan. There is a limit to how large it will go though, specifically a circumference of 2270 mm.
Calculate your new tires' circumference in millimeters, then multiply by a squish factor of about 97%. If that new number is over 2270 mm, then just put that in and call it a day. If it's less than 2270, then just enter whatever number you got by doing that calculation.
Cancunbadlands
Cancun
Cancun
Forscan can do it
daggerNC
2025 Maverick Hybrid XLT
Is 2270mm the correct FORSCAN limit for 2025 Hybrids? My factory 225/65-17 shoes are 2273mm circumference.... (also one of the factory model/option combinations have 225/55-19's which has a circumference of 2294mm) I'd like about a 1" lift for my '25 Hybrid XLT, and was considering putting 225/70-17's on which would give me a 0.9" lift, but those have a 2344mm circumference...? Has it been confirmed that Ford engineering specifies a "squish" factor? I haven't hooked up FORSCAN yet to my Mav, but would it show the actual (current) value set from the factory? (Sorry if this was discussed/verified already.)
CaliMav68
JL
Ohio
2022 Maverick Lariat AWD EB
I went from 225/60/18 to 245/60/18. Made a 1.5% difference in real world use. (About 1 mph at freeway speeds)
I personally feel you shouldn't give it another thought. Unless you like to tinker!🙂
Johnkn
MD
Lift math above is wrong....
A 225-65-17 tire is approximately 28.5" tall
A 225-70-17 tire is approximately 29.4" tall
Difference is .9" in height
Lift difference is ~.45"
Also, virtually zero major tire companies manufacture a 225-70-17 tire.
daggerNC
Absolutely right on the lift difference (not enough coffee yet?), and tire selection. Going to 235/70-17 would give me a 0.75" lift, but this raises the original question of being able to calibrate with FORSCAN at this size (2390mm)?
Johnkn
MD
Within the same manufacturer/tire family, there is only approximately a .9" difference in height between a 225-65-17 and 225-70-17 tire. That's .45" of lift.
Johnkn
MD
@Johnkn - I asked about a 235/70-17 tire which gives a .75" lift..
Here's your original post #7 where you stated that 225-70-17 tires would give you a 0.9" lift, then you changed the narrative..
Good luck.....I'm out...
"Is 2270mm the correct FORSCAN limit for 2025 Hybrids? My factory 225/65-17 shoes are 2273mm circumference.... (also one of the factory model/option combinations have 225/55-19's which has a circumference of 2294mm) I'd like about a 1" lift for my '25 Hybrid XLT, and was considering putting 225/70-17's on which would give me a 0.9" lift, but those have a 2344mm circumference...? Has it been confirmed that Ford engineering specifies a "squish" factor? I haven't hooked up FORSCAN yet to my Mav, but would it show the actual (current) value set from the factory? (Sorry if this was discussed/verified already.)"
