Speedometer and Larger Size (dia) Tires
Blueox76
Winona, MN
Ford Maverick Lariat, Ford Taurus, Ford Ranger
Can the speedometer be adjusted to indicate the correct speed with larger diameter tires?
EONR24
Swag
United States
2024 Ford Maverick XL
Dmat
Baton Rouge
MAVERICK
Check the link above. I believe it's doable in EZ mode but when you change it you will likely receive DTCs. which will go away if you reset your modules. Check those links in the spreadsheet
my link was the what the forscan spreadsheet links to lol
EONR24
Swag
United States
