Rear Spring Compatibility (Lobo/4K)
Tbone289
It could be, but the Tremor and Lobo have completely different springs so why would they both have the same lowered tow and payload? The only thing they have in common (which is different from other Mavericks) is the RDU
Because the Tremor has softer springs than the standard AWD as well. Many have commented about it riding softer.
justiz00
North America
I thought they ran a liquid cooled RDU and the twin clutch rear axle. Remembered that the RDU was what sent power to the rear after I started typing and just went with it.
Maverick123
Waiting
Oh! I thought RDU was Ford-speak for the twin clutch torque vectoring rear differential 😄 I can see how my argument sounds totally wrong
Thanks for correcting me. What I meant to say is that maybe the lower payload & towing limit on Lobo & Tremor is because of the special rear differential that they both use
Tbone289
Maybe. I'm not much for the speculation game, as it always seems a waste of time. If I get some time, I'll look to see if the specs are available from Dana. I wouldn't know where to look up the spring rates, but they have an effect on payload and tongue weight ratings as well.
a few tremor owners have installed airbag helper springs to address the sag that you get in a tremor when you're heavily loaded.
I see no reason that wouldn't work for this mod, also. if you have installed lobo rear springs and you want to haul 1500 pounds, or tow 4k, might be a pretty good idea to get the airbags.
Tbone289
Absolutely. It would still be good to know if, for some reason, the twin clutch RDU had some limitations as well but it seems odd to me. The concern might be clutch pack wear.
FSU TONY
Tony
South Florida
2025 Maverick XL 2.0
Installed the lobo rear springs today and removed the fx4 stickers. Changing the rear springs lower it about an
1 “.
1 “.
Did it change your driving confort or handling. Usualy they match the front and rear spring rates for better balance and manuverability
Pappamoto
Ken
2025 Ford Maverick Hybrid Lariat Shadow Black w/BAP
What did this cost? I'm assuming that it would cause warranty issues if they could blame the change in springs? I really like the even look though!
samandsuzy
SAM
Crawfordsville, Indiana
2024 XLT. FX4
Depends on the dealer. I think I paid 150 for both springs
I did not notice any difference
it is hard to tell in the pic. The back is only 1” higher than the front now
derek_tibbys
Derek
Massachusetts
2024 Ford Maverick
I also do not like the raked look on these trucks. I’m a bigger fan of the level look but don’t want to chew up CVs just for a look. I was wondering if you could provide the part numbers for the LOBO springs. Appreciate it. Truck looks great
