Rapid dash turn signal flashing
Palms
Gus
Jensen Beach, FL
21 Mercedes GLC; 23 Maverick Hybrid Lariat
My dealer’s mobile service unit came today and installed the rear light update software. While outside the turn signals flash at the same rate as before, on the dash indicator it’s at least twice as fast. Has anyone else experienced this?
Wizard
Russell
Kentucky
2023 cactus grey Maverick XLT
Mine is doing that as well but I have replaced with LED bulbs.
Palms
Palms
Gus
Jensen Beach, FL
I have the LasFits installed and this wasn't happening before the update. I did have the passenger side tail light not light up on ocassion.
Rolmav
Kansas City
2025 Maverick
I'm having the same issue with hyper flash inside not out. I'm pretty sure it has something to do with the recall and the LED bulbs. Sometimes it won't hyper flash or it will be normal speed for a second then hyper flash.
Ford Motor Company
Official Ford Account
Dearborn, mi
Good afternoon. Could you privately message us with your VIN and the name and location of your Ford dealer so I can look into this turn signal concern? Thank you!
Silver23
2023 Ford Maverick Lariat
It's the bulbs, simple. The truck doesn't like the LEDs.
Take it to the dealer you will get a nice bill for at least an hour labor. No warranty because you put those LED bulbs in and they are not compatible with the truck.
90south
Missouri
2022 Maverick Lariat AWD
Scheduled to have my software updated this Thursday.
Palms
Palms
Gus
Jensen Beach, FL
This wasn't happening before the update.
Mav_RICK
Rick
Arizona
Ford F150
So before the update the vehicle wouldn’t hyperflash inside which is the reason for the update. Now the vehicle does hyperflash and Silver 23 is saying it is reacting to your bulbs which sounds reasonable.
Mxer97
R
H town
2023 mav xlt
Try putting the oem bulbs back in
TOMV
TOM
PAPILLION NE
2023 FORD MAVERICK XLT HYBRID
Same Here Just had the recall done this morning now it is hyper flashing in the cab
Returned the bulbs back to Amazon to get a refund
LASFIT sent me the new T3-4257R to try
some times they hyper flash in the cab for about 1.5 seconds then they work fine.
Mxer97
R
H town
2023 mav xlt
I guess im going to take my led bulbs out before I get the recall, and then put them back in after to see if anything changes.
Skot5272
Pennsylvania
‘23 Maverick
I just had my update and I’m getting the hyper flash on the dash too. Exterior flash appears normal. No issues before with Lasfit bulbs.
nherweck89
Nick
Florence, KY
2022 Ford Maverick XLT
I was about to start a thread for this exact issue. Brought in my Maverick for a Check Engine Light and had a few recalls knocked out at the same time. After having my car for thirty seconds I noticed the hyperflashing inside but not outside. I called the dealer and he had me schedule an appointment for next week. Hoping someone comes up with a solution. I've got the Lastift bulbs installed throughout, hoping I don't have to go back to halogen bulbs...
It's already been hashed to death here: https://www.mavericktruckclub.com/forum/threads/hyper-flash-after-turn-signal-recall.41191/
Short version of story (my understanding/opinion only). Ford issued safety recall to correct a burnt out blub notification with the factory configured light bulbs. The safety recall software update cured the issue with factory lighting & blub types, however, it will cause the hyperflash on the instrument panel if you have changed to aftermarket bulbs like Lastfit, etc. but from what i understand the exterior blubs function correctly. That's my understanding - I could be wrong. It would also be my "assumption" that if you don't want the hyperflashing on the instrument panel, you'll probably need to purchase new LED blubs that are compatible with the software fix/update. or just don't get the update done.
