Ran a scan tool on my truck and picked up this code B1D55-13
MaverickSVT
Ohio
2000 Ford Contour SVT
I had the dashboard replaced in my Maverick
My only thinking is it could be related to that?
My Mav does not appear to have any issues with it either.
Is it potentially a problem to see this code or is it normal?
The scanner pulled some other codes but those say that they are not current
Ford Maverick Ran a scan tool on my truck and picked up this code B1D55-13 IMG_2048
Ford Maverick Ran a scan tool on my truck and picked up this code B1D55-13 IMG_2046
Carlitos_92
Is everything working as it should? What caused you to run the scan tool?
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
Do you have fuse 11 pulled by any chance? That would disable the Telematics unit.
Fender66
Scott
Charlotte NC
2025 Maverick Lariat
I recently had a similar experience when I installed side marker lights. I accidently shorted one of the wires. A week or so later I ran a scan and found an error unrelated to the light. I don't remember exactly but the code said something about an open circuit. The item was working fine. Then I remembered shorting the wire.
I cleared the error and did a rescan. The error did not reoccur.
MaverickDragon
Grand Canyon, AZ
That error would typically show up in the inability to receive FM radio.
I wonder if the error was caused when the dash was replaced.
If your FM works, clearing the code like @Fender66 did, and a rescan later would confirm that the problem was a historical artifact.
Otherwise, if the code show up again, the antenna cable may not have been properly reconnected during the dash reinstall.
MaverickSVT
MaverickSVT
Ohio
I have a newer scanner and I figured why not scan my maverick…
Carlitos_92
Sorry, I didn't see the mention of "not having any issues" until now. I was just wondering if both of those codes are really nothingburgers.
I don't know what "Antenna 2" is, but if Fordpass, Bluetooth, navigation, radio, SiriusXM, and any other antenna-using options are all working, it's probably a fluke. If something is NOT working, it sounds like maybe a cable didn't get plugged back in when the dashboard job was finished up.
ice445
Ryan
Utah
24 XLT Tremor
The backend software on these trucks is abysmal IMO, I'm sure most people could find stored "loss of communication" codes between random modules. On my truck, the audio module randomly loses communication (once every few weeks) with the screen shortly after startup, causing it to default to the cluster speaker for the start up bing bong chime for a few key cycles. You'd never know the code was there if you don't have a sufficiently advanced scanner that can read more than just engine codes. There aren't actual symptoms for a lot of these glitches.
I'm sure AI wrote most of this code, that or foreign interns lol
