Quality Black lugs?
bnhs1998
Brett
Tennessee
2024 ford maverick
Gorilla is what I have had ford dealership put them at tire rotation didn’t cost anything and got the old ones back
Ford Maverick Quality Black lugs? IMG_6616
Just to be clear.
You bought the black Gorilla lug nuts online?
Then you handed them to Ford when you had your tires rotated as a replacement for the OEM original chrome ones. Then Ford gave you your original lug nuts back to you?
bnhs1998
Brett
Tennessee
2024 ford maverick
Yes I still have them there mine I paid for them just ask for them if there is a problem ford put them on
OleFordGuy
I'm not 100% sure but was thinking the different wheels available could need different style lug nuts based on the seating needed. I seem to recall numerous threads/post from years past on this forum where that was pointed out. Just a thought to consider.
Hot Runr Guy
West Chicago, IL
What seems like decades ago someone bought an aftermarket "steelie", that had been sized for M12 studs, rather than the M14's that Maverick uses. The holes were just barely large enough, but the M14 lugnuts would not engage the conical taper.
I had a similar situation when using Bronco Sport wheels, which use a M12. There was a lot less engagement of the lugnut taper than the OEM Maverick wheels had. Not enough to fall off, but noticeably less.
HRG
Maverick123
25 hybrid
You're right, some wheels are designed for cone seat and others are designed for acorn seat. You need to get the correct lug nuts to match your wheels
