Problem with rear pax window on MY23 XL
TCPTX65
2023 Maverick XL Hybrid, 2023 Buick Enclave
Pulled into work this morning, put up my sunshade and went to crack the windows. When I went to crack the rear passenger window, I hit the button and the window went all the way down and now it won't go back up. (Since I work on a military base, I'm not too worried about theft right now.) When the dealership opens this morning, I will call for an appointment. My question is, has anyone seen or experienced this before, and if so, how can I get the window back up?
Numerous post about it, think most of time it’s a bad switch on drivers door. Search the forum and you can read details
TCPTX65
TCPTX65
I thought about that and tried rolling it up using the window switch on the rear pax door. No change. I'll search the forums again and see what I can find. Thank you.
Maverick2023
Kip
Atlanta, GA
Toyota Rav4
wait, there's no window switch on the pax door?
The switches are electrically linked together so either one being bad can break functionality.
If the switch hasn't failed stuck closed and potentially burned up the motor then the dealer tech who looks at it should be able to power the window back up at least.
paneubert
Seattle
I think the issue with the drivers switch is that it shorts out and provides constant "down" signal to the rear window. So the drivers switch would be fighting the input from the passenger switch and at most would let you roll it back up but then see it immediately roll back down again all on its own. At least that's what I recall others had happen to them. I think it was usually the rear drivers window, not passenger. But same concept.
TCPTX65
TCPTX65
That's what I'm thinking. Trying to get a hold of the dealer now. The thing that I don't understand is when I released the switch, the window kept going down (XL trim only has the driver's window with the one touch down feature).
TCPTX65
TCPTX65
Maverickman74
Shane
Maui HI
Cant believe they make XL buyers have power windows. If there is one part you know is going to fail on a vehicle its a power window. They never last.
Ford Motor Company
Official Ford Account
Dearborn, mi
Hi there! Would you send us a private message with your VIN and dealership name and location? I’d like to look into this concern on my end.
TCPTX65
TCPTX65
No worries. Got it into the dealer at lunch, had it back by 3. They got the back window up and have the switch on order and should be here Friday.
Wichita Falls Ford, Lincoln's service department is just as good as sales. If you're in North Texas check them out if you're looking for a new car.
