Possible tie down solution for tailgate assist?
kmish203
Jeep Renegade
There was a thread out there of a member that did an awesome job of fabricating a custom tie down that works with the tailgate assist strut. I tried to add this post to that thread, but it has been closed for new replies. I'll link it HERE if you haven't seen it already. Well I was searching around Amazon as I'm not a big fan of the tie downs that rotate and clank around as opposed to fixed ones like the bottle opener you lose and found these TIE DOWNS that were made for a Tacoma but seem to be a very similar angle as the custom ones referenced above.
Ford Maverick Possible tie down solution for tailgate assist? Screen Shot 2022-05-28 at 6.20.11 AM
I took a shot and ordered a set for myself, but my truck is currently in production so I have no way to test for sure if they will work or not. I feel like the angle is sharp enough that it will clear the bed sidewall when closed, just like the custom ones do in the pictures from the previous thread. If not I'm sure it could be pinched and modified slightly to fit. Again, I have no proof that these will in fact work but I thought it was worth a shot and wanted to share my Amazon find. They're prime so they shouldn't be a big deal to return if they don't work out. Maybe these will help somebody else out before I even get my hands on my truck. If somebody does try them, please post some pictures of your results!
EDIT: finally got my truck and they work perfect! See pics in a later post in this thread
huunvubu
coppell tx
2023 Ford Maverick Hybrid
This is the inexpensive solution that works for me. I have found that it does not as you suggest "flop around" or clang with the tailgate closed.
Ford Maverick Possible tie down solution for tailgate assist? CrocSee Bed Tie Down Anchor
Ford Maverick Possible tie down solution for tailgate assist? CrocSee Installed
kmish203
kmish203
Jeep Renegade
These are my backup plan. As I mentioned, I just prefer a fixed mount if I can make it work. With less moving parts there are less possible failure points.
huunvubu
coppell tx
I bought a set of four for $12.96 so I have three spares if needed.
These are also high strength and heavy duty:
  • HEAVY DUTY and DURABLE: CrocSee v-ring tie down anchors for trailers are made of high-strength steel for strength and longevity, and have an assembly break strength of 4,000 pounds and an awesome safe working load limit of 1,500 pounds per each ring.
I also wanted the replacement tie-down in the same position on the tailgate as the one removed.
Link to CrocSee Tie-Downs on Amazon
CrocSee 4 Pack Truck Bed Tie Down Anchors Trailer Cargo Hooks Bolt on D Rings V Rings Heavy Duty
kmish203
kmish203
Jeep Renegade
That's fine, just not my personal preferred option. Just sharing what I found as I've seen those V-rings all over the place but nobody has talked about this option
huunvubu
coppell tx
I used a hacksaw on the OEM and used half of it. Works great with a bit of black paint.
Do you have a picture of what it now looks like?
LC48
Johnson County Texas
Yes, a picture would be great @SkeeterB
@kmish203 if you wind up using one as @huunvubu illustrates above and it is "floppy" , before install place it on your anvil and using a round punch and hammer give it a couple small dimples as shown by the red dots on the pic below, go easy - check often
rclee
Rob
Dayton Ohio
Good Idea Skeeter! I am heading to the garage :)
Chris McD
Norwalk, CA
2022 Ford Maverick XLT
I like this solution since it tucks out of the way when the tailgate is down. I don’t have to watch out for it if I sit on the tailgate or step up to get into the bed. Ordering a set.
TheGriffin1313
Mongo
San Diego
22 Mav, 05 M3, 07GSXR
just installed the assist to find out that the bracket is deleted. I says "you need to remove the bottle opener"... As if this tie down main use is a bottle opener. I guess to help QA not notice that a tie down is deleted not just a bottle opener.... Excellent find though will be adding this
kmish203
kmish203
Jeep Renegade
I finally got my truck and installed the tailgate assist and these brackets work perfectly as a fixed tie down point in place of the lost bottle opener! I'll try to get some pictures later but they worked exactly as I had hoped previously. Highly recommend if you're looking for a solid bracket.
Chris_G
NOVA
C-6 Corvette
Did you use all four? Would you consider selling me one??
